Desktop Dyno my 352 setup please?
Old May 26, 2004 | 08:32 PM
original67's Avatar
original67
Sorry for having three posts going, but I dont want to group all of this into just one, it would be really confusing for me, this is the engine
Ford 352 .060 over or 4.060 bore
Forged Pistons 9.5:1 compression
Stock crankshaft and rods
Crane 343941 camshaft
stock rockers and pushrods
Pocket porting done to stock cylinder heads
Edelbrock performer intake with 650 cfm edelbrock 4 barrell
Longtube headers through 2.5" duals into glasspacks
I think that is all you will need, but if there is more, just tell me and i will fill in the gaps, thank you i appreciate it
Old May 26, 2004 | 08:44 PM
rusty70f100's Avatar
rusty70f100
I have it at 379hp @ 5500rpm, and 403ft-lbs @ 4000rpm.
Still planning on the nitrous?
Old May 26, 2004 | 09:44 PM
original67's Avatar
original67
Yeah I am planning on the nitrous, but it might be awhile, that is why I chose the forged pistons, how much does a normal kit cost for like a 150 shot
Old May 26, 2004 | 10:47 PM
fordman428's Avatar
fordman428
a kit for a 150 shot will run anywhere from $600-$1,000 depending on what kind of system you want, i think the fogger systems are the best because its sprayed right into the intake, but the ones that go under the carb arnt bad either.
Old May 26, 2004 | 10:56 PM
fordman428's Avatar
fordman428
i just noticed your pushing 379hp, my 390 only has about 375hp, 470# torque and i thought i had a better combo, i think its my intake thats hurting me. hey kurt can you run another DD for me, heres me combo
D3TE 390 block bored .060
stock 390 crank and forged rods
aluminum 9.5:1 compression pistons
fully ported C4AE stock heads, stock valve size
crane 941 cam and lifters
stock valve train
ported C4AE 4 barrell stock manifold
dynomax equal length headers into 2.5 dual exhaust with flowtech header mufflers
stock electronic dizzy
power tower 45,000 volt coil
8mm ford raceing plug wires
edelbock 750 carb
Old May 27, 2004 | 11:59 AM
rusty70f100
I dont have numbers for ported C4AE's. Therefore, I found the difference between unported C8AE's and ported D2TE's (they're basically the same head before porting). I added this difference to the C4AE file I had to get a rough guess of the flow numbers that ported C4AE's should flow. If you have exact flow numbers that would be best. According to what I've come up with, they even outflow ported edelbrocks by a very small margin.
Here's the results:
441hp @ 5500rpm, 455ft-lbs @ 4500rpm.
Old May 27, 2004 | 05:16 PM
fordman428's Avatar
fordman428
damn thats pretty cool, the only thing i changed from the last dyno i had was different pistons, and the 941 cam instead of the 901 cam.
Old May 27, 2004 | 05:54 PM
original67's Avatar
original67
I was wondering how much a roller valvetrain would cost for it, you know cam, lifters, pushrods, and rockers, how much all together, and are they hard to install, and adjust?
Old May 27, 2004 | 06:21 PM
rusty70f100
Keep in mind those are with estimated flow numbers for the heads. Get 'em ported and flow tested, then get back to me with the actual flow numbers. That way I'll be able to get it much more accurate.
Original67: I'd suggest you ask Gtex on this one.
Old May 27, 2004 | 09:42 PM
original67's Avatar
original67
Change of plans, can you redo the desktop dyno for this with cast aluminum pistons and 9.0:1 compression everything else the same, because nobody makes a forged piston for this set up.
Old May 28, 2004 | 11:22 AM
rusty70f100
I have it at 369hp @ 5500rpm, and 395ft-lbs @ 4000rpm.
Old May 28, 2004 | 12:28 PM
original67's Avatar
original67
I appreciate you doing that for me, well if i cant find pistons, that is only a ten HP loss and a 8ft lb loss, but the dissapointing thing is no nitrous with those cast pistons
Old May 30, 2004 | 10:38 PM
fordbeast_80's Avatar
fordbeast_80
you can still run 75-100 shot of nitros on cast pistons
wagonerkl
Sep 1, 2010 12:03 AM
weazel
2004 - 2008 F150
Jan 5, 2007 01:40 PM
302Xplorer
2004 - 2008 F150
Dec 30, 2004 08:06 PM
original67
May 27, 2004 09:57 PM
caseyatthebat1
Feb 2, 2002 12:19 AM
