Jumps in reverse
Old May 24, 2004 | 01:04 PM
RedneckF-150's Avatar
RedneckF-150
Jumps in reverse
I have an 81 F-150 300 six, four wheel drive, four speed o/d trans, with 3.73 gears and the posi in the rear. It jumps like a kangaroo when I start out in reverse, but not when I get going. It hops so bad I think my u-joints are breaking. It works fine foreward. It also doesn't do it in winter. What is wrong?
Old May 24, 2004 | 01:29 PM
Big Orn's Avatar
Big Orn
Have you checked the engine and transmission mounts? When they are broken or loose the torque of the engine will cause jumping.
Also, see if the ubolts and mounting plates on the springs are tight.
Old May 25, 2004 | 01:03 PM
RedneckF-150
All of my mounts are fine. The truck was completely rebuilt a few years ago. Could it be because I am not running a friction additive in the rear?
Thanks!
Old May 26, 2004 | 07:06 AM
Big Orn's Avatar
Big Orn
I don't think it has anything to do with the diff. You say you have a posi diff. Is it a locker or limited slip? You should have friction modifier on a limited slip diff, but on a locker it's not required as it would do nothing.
Back to the problem.
Jumping in reverse can be caused by loose mounts, supports, etc. from the engine to the rear differential. That would include the carrier bearing (if you have one). The '81 has a manual operated clutch where the "Z" bracket is attached at the frame and the bell housing. That bracket could be moving (caused by a loose engine or tranny mount) and "drawing" the clutch pedal away from your foot. Or the rear spring mounting plates could be loose causing the axle to wrap more than normal.
I would have someone look underneath the truck at the axle, driveline and tranny while you back up to see if there is play somewhere.
colour
22
Feb 16, 2021 11:41 PM
Richard.Parker
1997 - 2003 F150
Mar 5, 2015 06:31 AM
77429highboy
Jun 2, 2011 09:25 PM
WIN1MOR
Sep 3, 2006 07:34 AM
hamcginn
Sep 13, 2001 02:15 PM
