E4OD no reverse
Old Sep 2, 2006 | 08:37 AM
WIN1MOR's Avatar
WIN1MOR
Question E4OD no reverse
Just picked up a 96 F150 2 wd E4OD. The truck runs great and drives in all forward gears. Problem is no reverse. It also starts in gear but only when I jump the solenoid under the hood. Truck also wants to drive when shifted to neutral and seems to be locked up when in reverse. Any suggestions would be appreciated; I don't have any info about this truck's history. Trying to fix it up for my daughter.
Thanks; DanD
Old Sep 2, 2006 | 08:20 PM
projectSHO89's Avatar
projectSHO89
I'd start by checking the alignment/adjustment of the shifter cable/linkage.
Steve
Old Sep 3, 2006 | 07:34 AM
WIN1MOR's Avatar
WIN1MOR
I tried that already and it seems to hit each spot correctly. I was wondering how much this may have to do with the Manual Lever Position Sensor located on the side of the tranny. I know the E4OD is electronically controlled and gets most of its commands thru this sensor, but thats about all I know. Are there any tests I can do on this sensor or elsewhere before I give in and let the tranny shop have it? Thanks, DanD
Nitesaber
33
Oct 1, 2017 02:43 PM
dieselbro
Aug 26, 2012 07:26 PM
coalmanjhj
Sep 18, 2011 07:32 PM
tbart16
Feb 1, 2010 11:31 AM
handyman43358
May 22, 2005 03:52 PM
