fuel injection pump
Old Sep 27, 2001 | 02:40 PM
Jackson's Avatar
Jackson
fuel injection pump
Is dynamic timing of the injection pump something that can be done in the garage or are there too many specialty tools and guages needed? What all is involved.
Old Sep 27, 2001 | 03:29 PM
fordiesel69's Avatar
fordiesel69
fuel injection pump
You will need an inductive timing gun with a pulse adapter for the 6.9/7.3. The GM pulse adapter will screw in the hole but will not have the proper signal. Once you find that equipment, you need to find out the proper degrees directly from the ford manual, I have seen so many differnt manuals and they all have different specs. You want the specs from the ford manual. After that you will need to take a hydrometer reading from the diesel fuel and conpensate for the different cetane level.
If you want a detailed procedure, let me know and I will give it to you step by step.
1986 F-250 6.9 diesel,4x4,XLT Lariat,Ex Cab, 8'bed,etc...
Old Sep 27, 2001 | 04:23 PM
Jackson's Avatar
Jackson
fuel injection pump
Thanks, yes I would like the detailed procedure. If you want you can post it or E-mail it to me at qcox@cabq.gov. Again thanks.
Old Sep 27, 2001 | 10:15 PM
dinosaurfan's Avatar
dinosaurfan
fuel injection pump
Vinford
Sep 26, 2010 06:33 PM
swhess1227
Jun 16, 2007 08:47 AM
poston
Sep 19, 2006 09:49 PM
rhcountry
Feb 23, 2005 07:04 PM
rhcountry
Feb 19, 2005 11:12 AM
