Injection Pump Help
Old Sep 19, 2006 | 05:12 PM
poston's Avatar
poston
Question Help!!!!!!!!!!!1
I am have a problem with the injection pump on my 85 F-250 6.9. It has a new fuel filter, pump and injection pump. I am getting fuel to the injection pump but the fuel well not leave the injection pump. The lines have been flushed and there is fuel in the tank. I have been stumped on this for a week now.
Old Sep 19, 2006 | 07:09 PM
Beast12's Avatar
Beast12
Welcome to the site. I moved your post to the 6.9L Diesel engine forum. Should get some help here.
-Matt
Old Sep 19, 2006 | 09:21 PM
Dave Sponaugle's Avatar
Dave Sponaugle
poston,
Welcome to FTE and the IDI diesel forum.
Sounds like you are either not getting power to the fuel shut off solenoid, or it is not working correctly.
As you stand in front of the truck looking at the IP, you see two wires on the top right of the pump.
The front one closest to you is the fuel shut off solenoid, the rear one is cold start timing advance solenoid.
Both should have power when the key is in the ON position and the engine is cold.
If you unplug the front wire while the key is ON, you should hear a faint click as the solenoid closes. Touch the wire to the connector several times and see if you can hear a click each time you make or break contact with the connector.
Old Sep 19, 2006 | 09:49 PM
PLC7.3's Avatar
PLC7.3
If it is not what Dave stated it could be a plugged IP inlet filter screen or a stuck metering valve.
TruckingBill
Sep 3, 2014 08:01 AM
Dieseldriver13
30
Mar 20, 2013 05:04 PM
f250d4x4
Oct 27, 2011 11:11 AM
Deereguy90
Jul 27, 2011 09:26 PM
