interchangeable heads?
Old May 23, 2004 | 09:55 AM
Brian77Ford's Avatar
Brian77Ford
Quick question here. Can heads from a 351m/400 be replaced with heads from a 302? Thanks.
Old May 23, 2004 | 10:52 AM
bubbaf250's Avatar
bubbaf250
Quick answer: no.
Old May 23, 2004 | 11:16 AM
Brian77Ford
I didn't think so. Some c***y guy bet me 10 bucks that they were. I told him I can prove it to him.Thanks for the info.
Old May 23, 2004 | 07:22 PM
shazam's Avatar
shazam
Only the heads from the BOSS 302 can be made to work on the 351M/400..
ShaZam
Old May 23, 2004 | 08:16 PM
Brian77Ford
will they match up, or will they need some work to put them on?Why will these heads work but not regular 302 heads?
Old May 23, 2004 | 09:11 PM
shazam's Avatar
shazam
There is some futzzing to do to make them work ... You have to drill holes in the bottom of the heads to connect the block cooling system of the 351m/400, and then block off the intake cooling system they used on the BOSS 302's... But the Boss heads where the first Canted valve heads that finally made it onto the 351c, which most all of the 351c parts will work on the 351m/400..
Old May 25, 2004 | 02:35 PM
Brian77Ford
Thanks for the input.
deve
Sep 15, 2011 08:53 AM
jcarlson
2004 - 2008 F150
Feb 23, 2008 07:32 PM
buzzbait65
Nov 20, 2006 09:33 PM
uncle junk
May 7, 2006 12:00 PM
Bliath
Modular V8 (4.6L, 5.4L)
Feb 9, 2005 06:02 PM
