Engine ID
Old May 22, 2004 | 07:48 PM
ScottJM's Avatar
ScottJM
Engine ID
Got a new parts truck today with engine and transmission but cant find any casting numbers on block. The numbers on the intake are D6VE and the vin is F25JKD numbers were scratched couldn't read them. Can anyone tell me what motor this is from those numbers. Thanks
Old May 22, 2004 | 07:56 PM
fordman428's Avatar
fordman428
you cant tell what the engine is by #'s. but if its an FE it will have 5 valve cover bolts and the intake will extend under the valve cover and the spark plugs will sit like this \ \ / /
Old May 22, 2004 | 09:48 PM
BB's Avatar
BB
You got a 460, lucky dog.....
Old May 23, 2004 | 12:53 AM
fordman428's Avatar
fordman428
hey BB how did you decode that was that from the V in the D6VE, i figured if it was an FE you wouldnt have been able to tell by the casting #'s.
Old May 23, 2004 | 02:11 AM
BB's Avatar
BB
Yeah no FE had a V, that's a Lincoln code.
D6VE 9425 A3A is one of the 460 intakes used in trucks and vans plus the J in the vin is for a 460. The Lima engines are a little easier to id by their casting #'s.
Old May 31, 2004 | 05:27 AM
campinrig's Avatar
campinrig
Fourth character - ? - Engine Code
A - 6 cyl - 240cid - 1BBL carb - 1973-74
B - 6 cyl - 300 cid - 1BBL carb - 1973-80
G - V8 - 302cid - 2BBL carb - 1973-80
H - V8 - 351cid - 2BBL carb - 1973-80
Y - V8 - 360cid - 2BBL carb - 1973-76
H - V8 - 390cid - 2BBL carb - 1973-76
M - V8 - 390cid - 4BBL carb - 1974-78
S - V8 - 400cid - 2BBL carb - 1977-80
J - V8 - 460cid - 4BBL carb - 1973-780
I can track down others if you need me to
dentside owner
May 13, 2017 03:34 PM
newguy399
Jun 6, 2016 10:14 AM
444dieselrod
Mar 8, 2016 08:49 AM
Bill in Bama
Nov 19, 2015 06:13 PM
johnfretz
Modular V8 (4.6L, 5.4L)
Aug 5, 2004 09:43 PM
