Got a new parts truck today with engine and transmission but cant find any casting numbers on block. The numbers on the intake are D6VE and the vin is F25JKD numbers were scratched couldn't read them. Can anyone tell me what motor this is from those numbers. Thanks
you cant tell what the engine is by #'s. but if its an FE it will have 5 valve cover bolts and the intake will extend under the valve cover and the spark plugs will sit like this \ \ / /
D6VE 9425 A3A is one of the 460 intakes used in trucks and vans plus the J in the vin is for a 460. The Lima engines are a little easier to id by their casting #'s.
