Exhaust ?
Old May 22, 2004 | 07:05 PM
ltfox's Avatar
ltfox
Talking Exhaust ?
I currently have a 3"dp to a gutted kitty and then the stock 3 1/2" exhaust out. How much benifit will their be to going to a 4" exhaust. Also got a tymar intake. I mostly tow with the truck. Any opinions on what would be the best thing to do. I want to hear more turbo!!
Old May 22, 2004 | 08:27 PM
johnsdiesel's Avatar
johnsdiesel
With a 4" exhaust and a Tymar you will definately hear the turbo a lot more. It will also help keep the EGTs down.
Old May 23, 2004 | 07:57 AM
rosa70's Avatar
rosa70
I installed the 4" downpipe on my 99 and It actually made the turbo hizz inside of the truck quieter but outside through the tail pipe it was louder. Also check out the thread below for info on the downpipe. You might concider a smaller downpipe depending on the application you use your truck for.
https://www.ford-trucks.com/forums/s...d.php?t=241393
Old May 23, 2004 | 07:29 PM
bender97f250's Avatar
bender97f250
With the 4" your turbo will spool up quicker and egts a few degrees lower.
Old May 23, 2004 | 09:23 PM
rosa70's Avatar
rosa70
With the 4" my turbo spooled up slower than with my stock 3".
Old May 24, 2004 | 11:06 AM
ltfox's Avatar
ltfox
I lookin for a 4" exhaust that will bolt up to my 3" dp for a good price. Any suggestions?
Old May 24, 2004 | 11:41 AM
rosa70's Avatar
rosa70
There is a system by walker/Dynomax. It bolts up past the polution canister and rear intermediate pipe. You can get them at Advance Auto Parts for pretty cheap. You can also get the upper and lower intermediate pipe from Advance 4" but will have to find a reducer that goes from 4" to 3" plus there is a flange on the end of the downpipe that would need to be cut. I am currently working on my 99 year 3" downpipe to go to 4". You might to double reduce the 4" to 3 inch working in half in steps. If you would recommend just going 4" back like the dynomax system if you are going to keep allot of the engine stock.
Old May 25, 2004 | 07:52 PM
bigdieseldav's Avatar
bigdieseldav
I try not to sway peoples decisions when it comes to their vehicles, however I believe it is in your best intrests if you are going to go with a 4" exhaust in the first place to seriously consider at the least a 3.5" DP. The 3" stock DP is so restrictive that you would never see the potential of the 4" system the rest of the way back, and for the cost of the DP vs. the improvement, it would definately be worth it. I believe you should do whatever you are comfortable with as it is your truck, but i would suggest the DP changed if you are going to do anything with the rest of the system. To answer questions about price, I don't know about any DP back systems, but I got my diamond eye for 320 delivered. It also came with a 5" polished SS tip.
