93 Explorer Sport REVERSE LIGHTS problem
Old May 22, 2004 | 04:00 PM
mpviii's Avatar
mpviii
Hello,
I have a 93 explorer sport with the manual transmission. My reverse lights dont turn on. I have checked all the bulbs, sockets, and fuses. I have been told to check the switch that is mounted on the transmission. Can anyone give me detailed instructions as to where this is located and how to access it? Thanks in advance for the help.
-Mike V
Old May 25, 2004 | 08:31 AM
Jet Lizard's Avatar
Jet Lizard
Mike, I cannot provide you with any detailed instructions, but here's the picture from electronic parts catalog. I marked the switch with red circle. Hope this helps a bit.
With best regards,
Yuri
If you cannot see the picture, try this link: http://pics.binary.ru/full/93Ex-backup_lamp_switch.gif
Old May 25, 2004 | 07:24 PM
mpviii's Avatar
mpviii
Thanks for the help Jet, I'll take a look this weekend and see if I can find it.
Old Jun 8, 2004 | 05:31 PM
mpviii's Avatar
mpviii
Has anyone ever replaced the reverse light switch before? I now know that it is definitely the switch, I jumpered it manually and the lights come on.
Do I need to drain the tranny fluid before changing the switch?
Should I worry about any of those little parts in the above diagram that link the switch to the shifter falling down inside the transmission case?
-Mike V
Gabi Brice
Apr 18, 2014 06:49 AM
emedtech
Apr 12, 2006 12:11 PM
the_sport
May 6, 2005 04:04 PM
jgford
Jun 17, 2004 05:36 PM
lynn
Jun 9, 2000 12:46 AM
