Manual Transmission Problems - 93 2Dr Explorer
Old 01-11-2000, 01:08 PM
lynn's Avatar
lynn
lynn is offline
I recently bought a 1993 2dr 4.0 Explorer with 120K miles. I like it in every way except one. When the engine is cold, I have no problem shifitng into any gear from neutral. When the engine is warmed up, if I slide into neutral for a long traffic light, it is close to impossible to get it into first gear when I need to. If I am coasting, even slowly, it goes into first gear just fine. It is only a problem when I am stopped, go into neutral, then try to put it into gear. The same problem occurs with reverse, but in a different way. If the engine is cold, it goes into reverse just fine. If the engine is warm, it tends to grind when I put it into reverse. I had the transmission fluid checked and was told it was dark and well used. I changed it, but it hasn't improved this problem. Has anyone else experienced this problem? Any suggestions? Does it look like I'm going to have to replace the transmission?
Old 01-12-2000, 10:10 PM
JD's Avatar
JD
JD is offline
I had a '92 Sport with what sounds like a fairly similar problem. Mine kept losing just a little fluid from the master cylinder. There was no evidence of a leak anywhere so deduction pointed to an internal problem. As it turned out the slave cylinder was shot and the fluid was leaking into the bellhousing. The replacement part was around $100 but involved removal of the whole transmission. Luckily I have an uncle with a car lift...still a lot of work.
I say check the system's master cylinder (not brake master cylinder)to see if your fluid is low. If that's not it, I don't know what else it might be.
JD
Old 01-12-2000, 10:16 PM
58f100's Avatar
58f100
58f100 is offline
If fluid is dirty try flushing /changing, must drain from slave cylinder in bellhousing, or need to replace master/slave cylinder. It sound like your clutch may be sticking had same problem on ranger, 1991 with 168k, they wear out. ot your syncro's are bad, I had my ranger 5 sp rebuilt at 47 k, former owner towed trailer, good luck
Old 03-01-2000, 06:21 PM
steve Talbott
Guest
Posts: n/a
Old 03-20-2000, 11:34 AM
BExplorer's Avatar
BExplorer
BExplorer is offline
Recently I had a bearing that failed so had to get trans down, I changed the slave cylinder and all the inside components. My tech manual say to check the contact between slave cylinder and pressure plate, it could cause (if not correct)the problem you are refering to. The clutch could be not completly disengaged and your having trouble with gear.
Old 06-09-2000, 12:46 AM
drew22's Avatar
drew22
drew22 is offline
I have 96' explorer with basically the same problem, first I would have to say check the transmission fluid level and for leaks in the master cylinder. But what I think is wrong with your explorer and mine is that the slave cylinder/throwout bearing is starting to wear out and the clutch is not releasing completely. Fixing it is a pain in the *** cause you need to pull out the whole transmission. Good luck.
Nitesaber
33
10-01-2017 02:43 PM
MexicanScaper987
1999 to 2016 Super Duty
11-16-2012 08:24 PM
contramundum
07-18-2012 06:51 PM
hawkrdr
03-31-2009 09:47 AM
cfltitans
Aerostar
01-14-2006 11:18 AM
Quick Reply: Manual Transmission Problems - 93 2Dr Explorer
