Injector 02 F250
Old Nov 2, 2001 | 10:00 PM
dfbond's Avatar
dfbond
Injector 02 F250
I am thinking about buying a 2002 F250 PSD a friend of mine said that they are having problems with the injector after 50,000 miles. He also states that this is not covered under warranty. Can somebody confirm this.
Old Nov 3, 2001 | 03:04 AM
The Diesel Dude's Avatar
The Diesel Dude
Injector 02 F250
We have had some problems with broken rocker arms but we are out of it now. I am unaware of any problems with injectors and, as far as I know, the engine has a 100,000 mile waranty. Does anybody know if the injectors are covered for 100,000 miles?
Old Nov 4, 2001 | 03:59 PM
SSvec's Avatar
SSvec
Injector 02 F250
All engine parts are covered under the 100000 mile warranty, except the turbo which is only covered for 35000 miles, which means the injecters are covered, you shouldn't have a problem anyway, everyone i know has over 130000 miles on their diesel (99and newer) and has had NO problems whatsoever, we also get 17-20 miles to the gallon with stock engines with 4x4's, unless you are very, very unlucky, your truck will be perfect for over 150000 if you take care of it.
Old Nov 9, 2001 | 12:45 AM
0patience's Avatar
0patience
Injector 02 F250
There could be a problem with moisture getting into the system, but there is an update for it, should the truck have any hard start problems. As was said, the injectors would be covered under warranty anyway.
The only problem I have seen on the 2002 models is a couple heater core failures.
There is a recall on the wiper motor and driver's air bag.
Old Nov 9, 2001 | 10:29 AM
scaesare's Avatar
scaesare
Injector 02 F250
0patience-
Do you have URL's for these recalls? I have a new '02.
Thanks.
-Steve
Old Nov 9, 2001 | 06:20 PM
0patience's Avatar
0patience
Injector 02 F250
Sorry, no URL, but here is the Recall numbers.
You will need to check with your dealer to see if your specific truck is effected. It looks as though the info I had was wrong, I had the 2002 models affected, but it looks as though it is only the 2000 and 2001 models.
Recall 01V258000: Wiper Motor Gear Case Cover
These vehicles were built at the following assembly plants: plant from 2/11/00 through 7/31/00; Chicago plant from 2/14/00 through 8/4/00; Kansas City plant from 2/26/00 to 9/4/00; Kentucky Truck plant from 2/18/00 to 8/31/00; Michigan Truck plant from 2/23/00 through 8/3/00; Norfolk plant from 2/21/00 through 7/27/00; Wayne Stamping and Assembly plant from 2/25/00 through 8/15/00; and Wixom plant from 2/15/00 through 8/8/00.
Recall - Driver's Airbag Replacement
01S10
SAFETY RECALL
Certain 2001 Model Year F-Series, F-Series Super Duty, Excursion, and Expedition Vehicles built Through February 28, 2001 - Driver's Airbag Replacement
Old Nov 9, 2001 | 09:21 PM
alanscott's Avatar
alanscott
Injector 02 F250
cory5517
Oct 24, 2013 07:19 AM
f1501987
Apr 28, 2012 06:05 AM
Dustin460
Aug 11, 2009 06:02 PM
skidrow01
Modular V8 (4.6L, 5.4L)
Feb 29, 2008 04:14 PM
