replaced fuel filter
Old May 20, 2004 | 04:57 PM
wire4money's Avatar
wire4money
i replaced my fuel filter on my 2000 4x4 4.0 today. i have heard stories on everyone fighting the lines, so i invested in the line release tools. when i got under the truck, i popped out the little white clips all the way, and the fuel lines came out. i didn't have to use the tool. is this normal? the only one that fought me was the larger line with no clip on it. a little wiggle and it came out. i guess i'm just concerned at how easily the lines came off - without the white clip, there was NO resistance. At 40K, i assume this was the original filter.
Old May 20, 2004 | 05:08 PM
Vin 95's Avatar
Vin 95
The internal lock clips may be rusted or bent and not holding,not a problem if you have the plastic clips in place. I would check it once in a while for leaks or seapage.
Old May 20, 2004 | 05:37 PM
wire4money's Avatar
wire4money
is there any repair that can be done? the plastic clips feel loose. i would expect better engineering. the truck is a 2000 with 40K miles.
Old May 20, 2004 | 05:57 PM
Vin 95's Avatar
Vin 95
I dont know of any other than replacing the lines.Mine were a little loose,so I took a Small screwdriver and bent the little metal tabs that are inside the lines,then they locked securely.
Old May 20, 2004 | 06:02 PM
Rockledge's Avatar
Rockledge
I think I recall a similar post by someone with a '00 Ranger who also said he had no problems disconnecting the fuel lines from the filter on his truck.
I don't need a special tool to change out the fuel filters on my other Fords, either.
Not sure exactly what it means, though...
Old May 21, 2004 | 03:55 AM
PW01's Avatar
PW01
From what I've heard and read, they're all different. I'd just consider myself lucky!
Old May 21, 2004 | 04:23 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I've got those little white clips and they have been just fine for 171,700 miles and 9+ years. They are designed to lock when installed and can be easily removed with a small straight blade screwdriver. Nothing to worry about provided you inserted them in all the way when the filter was replaced. As for my fuel lines, they have virtually no resistance to sliding off when the clips are removed. I never looked in the fuel lines, but I suspect there might be an o-ring in there to provide a positive seal when fuel pressure is applied.
Old May 21, 2004 | 07:30 AM
wire4money's Avatar
wire4money
Thanks for the help. this site is so full of information - it's nice to have a place to go when i need a question answered.
Sonicmjf
Dec 20, 2017 04:31 PM
ceej4801
15
Mar 2, 2016 11:34 PM
Poppa Squirrel
Nov 17, 2015 08:46 PM
PEG
1997 - 2003 F150
Nov 12, 2014 12:27 PM
Travis Peters
Apr 21, 2003 08:53 AM
