99 Ranger braking issues
Old May 19, 2004 | 10:35 PM
chipnchevy's Avatar
chipnchevy
My truck has a loud clicking noise coming from under the driver side front tire when I brake. The brake pedal is not engaging properly, it is stiff, then gives a little, stiff then gives etc. The brakes aren't grabbing properly either. This doesn't happen every time, only about 80% of the time. I replaced the VSS a few months ago for braking and speedometer issues which did resolve, up until now, the speedometer is acting up again as well, but I never had stopping problems before. Please help.
Old May 20, 2004 | 12:33 PM
Ken00's Avatar
Ken00
Do you have 4 or rear wheel ABS and is it 2 or 4 wheel drive?
Old May 20, 2004 | 03:24 PM
chipnchevy's Avatar
chipnchevy
I'm pretty sure that it is 4 abs. 2wd 3.0L manual
Old May 20, 2004 | 08:47 PM
Ken00's Avatar
Ken00
I would be surprised if you did have 4w ABS, how many lines go the hydraulic unit.
What problem are you having with the speedometer.
Old May 20, 2004 | 09:00 PM
chipnchevy's Avatar
chipnchevy
I asked my uncle, (see, I'm just a girl) and he said that it doesn't have 4abs. Speedometer is basically bouncing all around, but if I let the gas off briefly, it will go to correct speed.
Old May 21, 2004 | 03:57 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I think it's time to pull the tire/wheel and do a visual inspection looking for damage/wear/misalignment/etc on the brake components. On the speedo thing, I'd check the contacts in the connector and on the VSS for corrosion. Pay careful attention to the contacts to make sure there is no damage (bent or pushed in resulting in a poor connection). Also, look at the wiring leading up to the VSS for any wear/abrasion/pinching which could cause a short. After that, I'd suspect you once again have a faulty VSS. Just because a part is new doesn't guarantee that it's not defective; once in a great while a bad part slips out the door. Did you save your receipt for it? If so, and since it's so easy to replace, I'd take it back and try another one.
Old May 21, 2004 | 11:39 AM
chipnchevy's Avatar
chipnchevy
I already had my uncle pull the tire, he checked all components, including the bearings, they were loose, but he tightened them, it didn't make a difference. I will go down to Ford today and buy another VSS and all wires have been checked. Thank you, I'll let you know if this works.
Old May 22, 2004 | 02:37 PM
chipnchevy's Avatar
chipnchevy
Okay, I replaced the VSS, didn't work. Today is the first time that it has rained since my problem started. I was stopped at a light, and when my windshield wipers kicked on, the speedo surged from 0-30 and the brake pedal did that ticking noise and began to depress more. This was all while I was stopped at a light. I am nervous about driving this thing. Please help.
Old May 22, 2004 | 03:12 PM
Rockledge's Avatar
Rockledge
On your '99, if you have RABS, then the VSS signal goes directly to the Generic Electronic Module (GEM),and from there it gets distributed to the computer, the cruise control system, and the speedometer.
If you have 4WABS, then the VSS signal goes to a seperate 4WABS Module first, then it gets distributed to the GEM, the computer, the cruise control system, and speedo.
So depending on your type of ABS system, you might next want to consider the GEM or the 4WABS Module.
Also, check the wiring harness under the driver's seat area. This is where some of the wiring relevant to the ABS system is located. There is a known issue with chafing and/or moisture getting under there and corroding the wires, causing symptoms similar to a bad VSS.
Old May 22, 2004 | 05:30 PM
chipnchevy's Avatar
chipnchevy
Okay, we took the front seat out, checked all wires.... no angry looking wires. All is clean and dry. I guess that I'll take it down to Ford on Monday morning and let them do their magic with all of their fancy equipment. Thank you all for your help. I'll let you know what they say.
Old May 24, 2004 | 04:34 PM
chipnchevy's Avatar
chipnchevy
Okay, thet said that it is the RAB & module, they are quoting me $229.92 + installation and tax. Is this something that I can do myself(is it complicated), or do I have to have them do it? I called my local parts store and they said that you have to get this part from Ford.
Old May 24, 2004 | 05:40 PM
Rockledge's Avatar
Rockledge
The 4WABS Module needs to be programmed after it is installed. It is located under the hood, bolted right to the ABS hydraulic assembly.
However, I believe if you have just have RABS, then your module is replaceable without needing to be programmed. It is located behind the ashtray a little to the right, you have to yank the radio and ashtray assembly to get at it. You can get a remanned unit from RockAuto, if I recall correctly.
Maybe someone else can confirm this.
Old May 25, 2004 | 08:55 PM
chipnchevy's Avatar
chipnchevy
I'm gonna take it to Ford and let them replace it. They won't warranty the part if they don't install it.
Old May 25, 2004 | 11:16 PM
Rockledge's Avatar
Rockledge
I guess sometimes we all have to take one on the chin....
Let us know how it turns out.
Old Jun 5, 2004 | 11:48 AM
chipnchevy's Avatar
chipnchevy
Well, it seems to have worked. Still disappointed in my dealership, they managed to squeeze 560.00 out of me for a 229.00 part, but my truck stops safely and effectively now, and I guess that's worth it.
SuperDuty93
Jul 7, 2016 06:12 AM
kyle j
Apr 23, 2016 05:44 AM
cpye2
17
Mar 10, 2016 09:40 AM
anthonym92
53
Sep 8, 2015 02:15 AM
cander06
Apr 16, 2015 12:08 PM
