ATS Turbo?
Old Nov 29, 2001 | 10:28 PM
87f2504x4's Avatar
87f2504x4
ATS Turbo?
I am looking at a truck, a 1990, with a 7.3 turbo, that was obviously added. The top of the motor says ATS turbo. Is this aftermarket, and if so, is it any good? Also, is a diesel supposed to blow smoke under hard acceleration? Please advise ASAP - looking to buy this truck!
Old Nov 30, 2001 | 03:36 AM
Roaring's Avatar
Roaring
ATS Turbo?
as far as I know the ATS is the one used by Ford although the motors in that year were not turboed.
as for the pushing smoke under load yes they will... it is unburnt fuel as far as I know that you are seeing...
hope this helps and I have not misinformed you.
Old Nov 30, 2001 | 10:00 AM
ddestruel's Avatar
ddestruel
ATS Turbo?
If the mechanical pump is turned up a little yes it will blow smoke under hard acceleration even a stock motor will blow smoke, as to the turbo, the ATS is a fine unit mid to upper range performance where as i have heard the Banks is more off the line to high mid range where the wastegate opens. Five speed or auto, good truck either way interms of the motor no electric injectors like the newer PSD's less to deal with. Good luck hope this helps
Old Nov 30, 2001 | 01:23 PM
The Diesel Dude's Avatar
The Diesel Dude
ATS Turbo?
Fireman_dave
WTB - Parts & other
May 17, 2014 10:31 PM
429 f-100
38
Aug 24, 2011 07:27 PM
Bluecrew250
Aug 1, 2011 07:06 AM
wb6anp
Feb 26, 2008 11:49 PM
