Starter won't disengage
Old May 19, 2004 | 10:12 AM
bdgauld's Avatar
bdgauld
I am working on a 92 Ford Explorer with a 4.0L motor. It came in with a starter problem and I replaced the starter. Now there is a noise coming from the starter that sounds like it is staying engaged. I tried replacing the starter thinking it may have been a bad rebuilt starter but the noise is still there. If I inplug the alternator the noise goes away. I have also tried replacing the alternator and the solenoid. Any help would be appreciated, I am stumped.
Old May 19, 2004 | 10:15 AM
fishmanndotcom's Avatar
fishmanndotcom
what kind of noise?
i had a problem with one sticking so i loosened the mounting bolts and moved it around just a lil bit until i got it just right. also on a lot of starters there are shims you have to use to keep the gear teeth meshed just perfectly. w/o shims it will grind.
-cutts-
LloydH
Aug 8, 2015 08:19 AM
forestgreen
22
Jul 13, 2015 05:52 PM
David LaPell
Jan 6, 2014 12:12 PM
packrat56
Feb 17, 2006 01:16 PM
dgalloway
Feb 24, 2005 06:46 PM
