Alternator getting hot and making noise - Ford Truck Enthusiasts Forums
Old 07-09-2015, 08:39 PM
forestgreen
forestgreen is offline
forestgreen is starting off with a positive reputation.
I have a 1969 f100 ranger and the alternator gets hot fast and makes a whine noise when I step on the gas. I had tried fixing the problem by replacing the solionod, starter, battery, alternator, regulator, and the wiring harness from the alternator to the regulator. (All in that order)
Mechanic shop looked at it and told me to replace the alternator again. This will be the 2 time... But still gets hot and makes noise.
Old 07-09-2015, 08:55 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
ultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud of
Do you have any electrical accessories that are placing a high amperage load on the alternator --such as an aftermarket stereo and amp(s)?
Old 07-09-2015, 09:02 PM
forestgreen
I have a cb radio but I disconnected it. Radio is disconnected as well
Old 07-09-2015, 09:06 PM
ultraranger
That pretty well rules out a high amperage load putting a drag (resistance to turning) on the armature.
Is this a bearing noise or a belt slipping on the pulley noise?
Old 07-09-2015, 09:12 PM
forestgreen
It's not the belt. It's sounds like a bearing. But I have bought 3 alternators in the past 2 months because some one had said the alternator is bad. When I step on the gas you can hear the alternator whining.
Old 07-09-2015, 09:18 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Welcome to FTE!
Also, first rule out a defective battery. If it does not accept a charge correctly for example, it will smoke the alternator.
Corroded connections, and grounds presents a similar problem, the regulator "sees" this as a battery needing charge. Constantly. This will ruin the battery. See the problem? It's important that charging system sees as low a resistance as possible, and a serviceable battery.
Get your DVM out and run some voltage tests at 2000 RPM with lights and heater on. At "normal" temps should see around 14.3 volts, say. "Voltage drop test" would probably tell the tale here.
First rule out the battery though.
Old 07-09-2015, 09:21 PM
ultraranger
If the V-belt is being over tightened, then it can damage the bearings.
If all the components you mentioned have been replaced and, if there's not a high electrical load on the alternator and the belt isn't slipping, I'm not sure what the reoccurring problem with it may be.
Old 07-09-2015, 10:14 PM
CougarJohn
CougarJohn is offline
CougarJohn has a good reputation on FTE.CougarJohn has a good reputation on FTE.CougarJohn has a good reputation on FTE.
If he is running at, let's say, 2000 rpm highway speed and he doesn't hear the whine, that says something. The alternator is putting out whatever the regulator calls for. If he hits the throttle and hears the whine, how does the alternator know about the throttle position and sense that it is time to whine?
This one is puzzling.
Belt squeal on acceleration?
Squirt some WD-40 on the belt(s), see what happens, report back.
Old 07-10-2015, 03:05 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.
Sounds like a internal short to ground to me. Is this a cheap parts store alternator? That's prolly the problem. I've heard those cheapy rebuilts are built with low temp solder in them. Which melts. I suggest taking it back for warranty and buy the best one they got. OR better yet, do the 3G swap.
Old 07-10-2015, 05:07 PM
CougarJohn
Pluck the connector out of the regulator and try again. Then, the alternator is freewheeling, no load, no diode currents. Or, take it to a competent auto electric shop and have them put an oscilloscope on the alternator output.
Check and see if the belt(s) are riding too deeply in the groove(s). Then, get suspicious of the water pump and power steering pump. Drop belts if you can.
I suspect you have a mechanical problem, not an electrical problem. You have thrown every possible electrical part at it and still the problem persists on acceleration.
Old 07-10-2015, 07:46 PM
orich's Avatar
orich
orich is offline
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
I wouldn't put any WD-40 on any of the belts as it will cause it to slip. But chalk will quiet a belt down and will not be sucked into the rubber & fibers of the belt..
Have the alternator tested where you got it. And are you using the correct size belt?
What's the voltage at 2000 rpm ? when it starts to whine .
You sure it's not the ps pump or belt.
Orich
Old 07-12-2015, 05:52 PM
forestgreen
I believe it's a short. I've gone threw 3 alternators there all good though. And recently since driving it the wiring harness is starting to get hot its melting the wires. Thus one is very confusing can't seem to find the problem.
Old 07-12-2015, 05:54 PM
forestgreen
The wires are melting on the wiring harness now. I think it's a short. But can't find it
Old 07-12-2015, 09:01 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.
Scrap it all and put in a 3G!!!
Old 07-12-2015, 09:34 PM
CougarJohn
Melting harness?
Yes, you have the mother of all shorts.
Start feeling around for heat. Fuse box? Ignition switch? Headlight switch?
Start dropping circuits at the + side of the solenoid. What aftermarket stuff has been attached?
Do the lights work? Brake lights?
Get an ohmmeter. Disconnect the + side of the battery and look in. You will see zero ohms with that kind of a short. Start pulling connectors, fuses one-by-one.
We cannot tell you where your short is. They can be dogs to find.
Troubleshoot.
The forum has all the circuit diagrams that you will need.
Quick Reply: Alternator getting hot and making noise
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
