351m
Old May 18, 2004 | 02:32 PM
DMAN's Avatar
DMAN
351m
I have a 78 f-250 that had a 351m in it but it went boom and was replaced with a 302. The 302 went bang and now I have a 351m I want to but back into it will this bolt in or do I have to change anything also the 78 is 4X4 and the engine is out of a 77 f-150 2X4 will I have to change the oil pan?
Old May 18, 2004 | 10:55 PM
Breeze's Avatar
Breeze
4x4, you should use a rear sump pan, and the 351 uses a different trans bolt pattern then a 302. Stick you can change the bellhousing, auto you need to swap the trans
Old May 19, 2004 | 01:35 AM
351M's Avatar
351M
Engine mounts on the frame have to be changed as well I think
Green Streak
Engine Swaps
Sep 23, 2019 05:18 PM
Puppo78
Nov 13, 2013 12:58 PM
georgiafordman78
15
Oct 2, 2006 07:54 PM
miichael
16
Mar 4, 2006 10:00 PM
superscythe
May 8, 2003 12:38 AM
