351m -460 swap
Old Nov 12, 2013 | 07:40 PM
Puppo78's Avatar
Puppo78
351m -460 swap
I Have a 78 f150 supercab that I have converted to 4x4 I have a 460 I'd like to swap in, do I need to change the mounts on the chassis to accomplish this?
Old Nov 12, 2013 | 09:04 PM
Pickupmanx2's Avatar
Pickupmanx2
Welcome to FTE Puppo!! Congrats on going to 4x4, the search engine on here isn't the best, but check it out. If IRC and you still have the 2wd frame, I think you will need the 460 mounts.
Old Nov 13, 2013 | 09:44 AM
scooter79's Avatar
scooter79
swap.
Contact L&L products. He is extremely helpful. Go me everything i needed when i did my swap.
Old Nov 13, 2013 | 11:02 AM
Puppo78's Avatar
Puppo78
Okay I'll give it a shot thanks for the advise!
Old Nov 13, 2013 | 11:03 AM
Puppo78's Avatar
Puppo78
Ill check it out thanks for the advise
Old Nov 13, 2013 | 11:04 AM
Puppo78's Avatar
Puppo78
Ill check it out thanks for the advise!
Old Nov 13, 2013 | 12:58 PM
Roger Carter's Avatar
Roger Carter
If the stock 2wd front cross member is still in the truck you will be able to use original Ford 460 frame stands and mounts. This will be a bolt in deal.
L&L does make conversion mounts that use the 2wd frame stands. These mounts are also a bolt in. The L&L number (from an older catalog) is #030495.
Again, this information only applies to a stock 2wd frame and front cross member.
Roger Carter
Lynch97
Apr 5, 2015 05:10 PM
pumpdriver20
Jul 29, 2013 10:21 PM
69highboy
Engine Swaps
Jun 27, 2004 12:26 AM
flatliner
Nov 11, 2003 07:21 AM
fordlowboy
Feb 25, 2002 08:55 AM
