Sponsored by: Auxito
Codes P1406 and P0401
Old May 18, 2004 | 09:56 AM
tsoileau's Avatar
tsoileau
I need suggestions and directors for the P1406 and P0401 codes. Could these two codes be caused by the same thing? I just changed my plugs, could I have disconnected something that would cause this? I have a 2000 F-150 with a 5.4L engine. Engine is running fine at normal driving. Hesitates when I try to "gun" it (using passing gear). Will change fuel filter. Thanks for your help.
Ted Soileau
Old May 18, 2004 | 12:23 PM
50th ann's Avatar
50th ann
P0401
There are several reasons a P0401 code can appear. I just fixed my 98 F150 4.6 L 112,000 Miles with the same code. It turned out to be the EGR Ports were clogged with carbon. Disconnect the vacuum hose from the ERG Valve and cap it. Then apply vacuum (outside source) to the ERG Valve while the engine is idling. If it continues to run smoothly the ports are blocked. The engine should stumble or stall if the ports are clear. To clean them you will have to remove the throat from the manifold. The EGR Valve or the PDFE Switch could also be the problem. I don't know about the other code.
Good Luck
JarrettCox
21
Feb 20, 2016 08:24 PM
ballbandit
May 22, 2013 07:52 AM
Schlava
6.7L Power Stroke Diesel
Oct 10, 2012 06:32 PM
weberr7
Jul 2, 2012 03:22 AM
Dialtone
General Automotive Discussion
Mar 31, 2008 02:47 PM
