egr delete/p0401
egr delete/p0401
i have a 06 6.0 with 74k miles on it. did a egr delete, new oil cooler, stand pipe and dummy plugs. left egr valve plugged in. now i get the p0401 code. cleaned iat sensor but no luck. any ideas what could be causing code. kinda obvious i disturb something. thanks for any help.
Basically it comes down to this. Yes your EGR valve is there and the electrical connector is connected however the truck utilizes the MAP sensor to reference a difference in pressure in the intake manifold to know when the EGR has opened. When you have a loss in pressure (EGR open) the the MAP sensor will pick that up. No drop tell the computer something is wrong. The only way to fool the computer on 05s and up is with a tuner. All this of cours IIRC.
I thought an SCT 3015 could turn the valve function off and kill the CEL without actually doing a tune.
You can also send your PCM to PHP, and they can load in a stock rollback with the EGR off and no CEL. $150 plus shipping compared to $325+retail for a tuner.
Sarge
