Is It Safe To Drive???
Old May 18, 2004 | 03:25 PM
evin's Avatar
evin
can a ball joint or tie rod make that noise and how dangerous is it to drive Im at work and have a 30 mile drive home dint know if I should drive it.
Old May 18, 2004 | 03:34 PM
Oscar Meier's Avatar
Oscar Meier
A worn or loose idler arm, tie rod or shock will make a clacking sound when you hit a bump - I would say if you take it easy for the trip home and watch for chuck holes and the like you'll be OK.
Old May 18, 2004 | 03:51 PM
evin's Avatar
evin
which is the idler arm Im not familliar with front end parts at all
Old May 18, 2004 | 06:40 PM
Bear 45/70's Avatar
Bear 45/70
If it was a steering componet you would have very sloppy steering and probaly feel it in the steering wheel. I'd check the springs, as a broken leaf will be noisy on hitting holes or bumps. A missing bushing in the anti-sway bars would do it too.
Old May 18, 2004 | 07:30 PM
Big Red's Avatar
Big Red
Here is a suggestion... I had a similar noise that turned out to be the stone shield on the front wheel that was half rusted off and would bang and clang when going over bumps. Check it out.
Old May 19, 2004 | 11:56 AM
evin's Avatar
evin
What And Where Is The Stone Shield?
Old May 19, 2004 | 01:55 PM
Bear 45/70's Avatar
Bear 45/70
Covers the brake disc's.
Old May 19, 2004 | 05:56 PM
bremen242's Avatar
bremen242
my front disc brake pads make that noise.. I'd look underneath for loose stuff, like brackets, suspension, and if you can't find anything, keep it under 80, and you'll be good..
Old May 20, 2004 | 10:43 PM
alcan60283's Avatar
alcan60283
Look at your radius arm bushings. They could be bad and when you hit a bump, the arm will slam into the bracket. Cheap insurance, if i remember, the bushings were $13 a piece.
Old May 21, 2004 | 06:52 PM
fordtruckman23's Avatar
fordtruckman23
On the 78 Ford trucks the caliper is held on with a spring loaded piece of metal and a small bracket with a bolt holding it in place. If spring loaded metal gets worn it will sound like front end is falling apart. Gone through this twice. I believe the 85's are similar to the 78's.
Hope this helps ya.
Old May 22, 2004 | 03:01 AM
earmstrong's Avatar
earmstrong
if the rattling noise is coming from the front passenger side, then it might be you idler arm. i've replaced mine twice. the steering becomes very sloppy and you feel like you need an alignment. usually the bearings go out on the idler arm, which causes it to sound lke something major is rattling around when driving over the slightest bump or dip.
to answer your question, "is it safe to drive," i would say sorta. if it is in fact the idler arm, i'd get it fixed before it causes stress on other things like the pitman arm. you'll be shelling out $$ if it gets that bad.
Old May 22, 2004 | 08:11 AM
fai4g63's Avatar
fai4g63
I am confused I have never seen a 80-86 Fseries truck with a idler arm. I thought there was a drag link that came right off the pitman arm that goes to the tie rods.
I know the 97 f150s and newer, use a idler arm.
Old May 22, 2004 | 08:15 AM
  #28
bremen242's Avatar
bremen242
you are right- the draglink comes from the pitman arm and attached to the passenger side knuckle, then the outer tierod attaches to the high part of the draglink, and then attaches to the driver's side knuckle..
Old May 30, 2004 | 12:26 AM
  #29
P1ckup Man's Avatar
P1ckup Man
on my 1979 f-150 those trailing arm or whatever they are. The rubber piece (bushing i think) was worn out and fell off and i had like 4 inches of play my front axle would move that much i replace both sides and drives like new no more annoying noise goin over bumps, dunno if this helps
vinnyb541
2004 - 2008 F150
May 28, 2014 03:03 PM
nbl346
13
Nov 15, 2012 09:29 PM
jlouki01
Feb 3, 2005 06:56 AM
FX4x4x4
2004 - 2008 F150
70
Aug 18, 2004 01:23 PM
Munkey
May 8, 2002 03:07 PM
