Sponsored by: Kumho
steering arm
Old May 17, 2004 | 05:27 PM
steveo420's Avatar
steveo420
steering arm
Anybody know a trick to remove a steering arm off a 1977 Highboy.I've loosen the nuts and drove around for 2 weeks (worked for my girlfrieds non ford) .
Old May 18, 2004 | 12:22 PM
dieingford's Avatar
dieingford
If I understand correctly you loosened the hardware holding the arm on and DROVE around? What would have happened if your idea did work? An Accident? I saw a mid size car missing a couple of lug nuts. It sheard of two of the others and was working the 5th one loose when the guy drove into the shop. Another mile and he would have lost his tire. Use an air hammer and a torch to warm up the arm (Don't cut the arm) if the arm gets damaged buy a new one. Alot cheaper then paying for someone's life if you lose the steering and jump a curb or hit a car head on. Just my $.02
Old May 19, 2004 | 04:58 AM
rebocardo's Avatar
rebocardo
If you mean the pitman arm, use a pitman arm puller or a gear puller. Though cheap gear pullers (2 arms) tend to be a bit wimpy and will bend if they are used for anything other then a straight pull.
Old May 19, 2004 | 05:37 AM
steveo420's Avatar
steveo420
not the pitman arn the steering arm on the axle
KsHighboy
Dec 12, 2016 04:06 PM
Rollingscrapmetal
Nov 5, 2016 05:42 PM
Highboy74
Oct 5, 2016 09:58 PM
Obowersox26
Sep 17, 2015 06:55 AM
mjshagnasty
Nov 16, 2010 01:10 PM
