Highboy steering
Old Oct 28, 2016 | 08:38 AM
Rollingscrapmetal's Avatar
Rollingscrapmetal
Highboy steering
My highboy has a 3 or so inches lift so the po extended the steering arm 3 or so inches making it nearly impossible to turn
I thought the power steering was out in it at first but while I was on the highway it seemed to work sometimes have a delay others not work at all other times so I know it's working intermittently
My thoughts so far are too flip the end of the arm that comes off the knuckle and shorten the steering arm up to match
What do you think
Old Oct 28, 2016 | 10:53 AM
mountain dewd's Avatar
mountain dewd
Make sure your pump is working. When mine died it was intermittent before going completely. Do you still have power assist?
Old Oct 28, 2016 | 11:35 AM
Rollingscrapmetal
It's the original steering setup I think it's the Bendix kind
I don't know if it's working at all honestly but it's always a pain to steer now no intermittent anything whether it's because I'm just moving it around a parking lot now instead of the highway or what
Old Oct 28, 2016 | 11:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Rollingscrapmetal
It's the original steering setup I think it's the Bendix kind.
Garrison Power Assist P/S: 1973 F250 4WD; 1974 F250 4WD before serial number T80,001.
Bendix Power Assist P/S: 1974 F250 4WD from serial number T80,001; 1975/77 F250 4WD
The serial number is the last 6 digits of the VIN
Old Oct 28, 2016 | 11:50 AM
Rollingscrapmetal
It's the Bendix kind then
Old Oct 28, 2016 | 11:54 AM
Rollingscrapmetal
What it is is I believe it's working mostly right its just the steering arm is too long so less leverage making it harder to steer
Old Nov 5, 2016 | 05:42 PM
Rollingscrapmetal
See what I.mean about the steering arm being too long
I found spacers for the arm on the kingpin if dana 60 ones will fit plus I found arms that are basically bent versions of what it came with again assuming dana 60 ones fit
Ole yeller77
13
May 26, 2019 01:59 AM
Macscustoms
Mar 28, 2017 11:49 AM
joshcwa
Sep 15, 2015 12:21 PM
Nktrnl
16
Apr 12, 2014 03:42 AM
68futura
34
May 12, 2009 09:58 PM
