Oil pan drain plug problem
Old May 16, 2004 | 07:27 PM
cjf5150's Avatar
cjf5150
The current drain plug on my '74 F250 (460 engine) is a little stripped out and doesn't seal properly. It slowly leaks oil, but enough that it is a problem. The current plug is a self tapping bolt with a drain bolt in the middle, so it looks like an aftermarket bolt that was put on the truck years ago because the oil pan threads were stripping.
Need to know if there is something else out there that could seal this. I saw an article in Popular Mechanics once that showed a rubber cork-type piece that expanded to fit the hole when you tapped in a center expander. I've tried Autozone, but all they have is the same drain bolt I currently have.
Any thoughts would be appreciated.
Chris
Old May 16, 2004 | 08:29 PM
fordman428's Avatar
fordman428
i had a similar problem, i fixed mine by useing a rubber seal, it seemed to work. i guess it depends on how bad it really is.
Old May 16, 2004 | 09:03 PM
Torque1st's Avatar
Torque1st
Posting Legend
Bite the bullet and replace the pan.
Old May 17, 2004 | 10:27 AM
hookin'78's Avatar
hookin'78
Advance Auto has your rubber plug but I wouldn't use it I am pulling the motor out of my daily driver today to fix the same problem.
Old May 17, 2004 | 02:24 PM
cjf5150's Avatar
cjf5150
Thanks for the suggestions. I found a rubber expandable plug at Napa, and will try that this week. I only drive this truck on weekends, so I'm just not ready yet to try and replace the oil pan.
When I do get to the point of trying to replace the pan, what is all involved with the 460? I assume I would need to unhook the exhaust and radiator hoses to lift up the engine high enough to get the pan off, but would I need to also unhook the tranny/driveshaft, etc? Never done that before, so I just don't know what I would be getting into.
Old May 17, 2004 | 10:53 PM
jimlj's Avatar
jimlj
Clean the plug and put a dab of rtv on the threads. I never have a drip this way.
Old Jun 1, 2004 | 04:34 PM
cjf5150's Avatar
cjf5150
Re-Tap?
Can I re-tap the threads on the pan and put in a larger bolt?
FSJ-EARL
16
May 12, 2015 10:10 PM
Gigemags05
Feb 15, 2015 12:04 AM
Argess
Jul 28, 2011 05:00 PM
schmitty99
May 8, 2011 09:17 PM
berg87
3.8 & 4.2L V6
Apr 30, 2008 01:50 PM
