Manual Trans
Old May 15, 2004 | 01:02 AM
Sanders's Avatar
Sanders
Manual Trans
I was wondering does anybody know of a good five speed tanny for a 68 F100. I have a very strong 302 and a weak C4 in the truck. I have looked at rebuilding the C4 but a five speed manual would be a much cooler. I need a tranny that has the shifter more toward the driver's side. I have looked at a few already and they have the shifter coming straight up from the top which would put the shifter to far away. Any suggestions?
Sanders
Old May 15, 2004 | 01:38 PM
rebocardo's Avatar
rebocardo
That is why most top loaders have big long bent shifters, including the top loaders in trucks. You can easily find a T-5 or Tremec to put behind a 302 because they come in Mustangs.
It sounds like you have a 2x4 so I would suggest buying the strongest manual you can afford and adapting the shifter from a standard truck 4 speed (Np435 or T-18) to whatever manual transmission you choose.
Old May 15, 2004 | 02:55 PM
Sanders's Avatar
Sanders
Does the T5 or tremec have any electronic hardware that has to be wired up? I am going to a juckyard on monday to see if I can get a shifter from an older truck.
Sanders
Old May 15, 2004 | 10:22 PM
1982fordf100's Avatar
1982fordf100
The new Tremec TKO 500 and 600 have a mechanical or electronic speedometer hook up, a electronic back up switch and a neutral safety switch. They also have a new shifter handle option which moves the shifter 2 inches offset of the main shift rail. Fred
zenish
Aerostar
Jun 14, 2016 08:43 PM
78 F150
Dec 14, 2008 12:29 AM
Fair 96
Paint & Bodywork
Sep 2, 2007 01:29 AM
Sanders
Apr 7, 2004 09:32 AM
