Rumbling noise
Old May 14, 2004 | 10:04 AM
kolysrock's Avatar
kolysrock
Rumbling noise
My 2000 explorer sport is making a rumbling noise, while driving. it doesn't seem to change with speed up to 45 mph, then it quiets down and road surface conditions don't affect it... I was thinking i needed to change the differential fluid.
Any Suggestions???
Old May 14, 2004 | 04:15 PM
daerhldgs2's Avatar
daerhldgs2
could be a front wheel bearing
Old May 14, 2004 | 05:42 PM
kolysrock's Avatar
kolysrock
I considered the bearings being bad as an option also but I thought that the rumbling noise would change when turns were made...
Is this a for sure indication or just one of many indications that are possibly.
I did notice a high pitch squeal which goes away with speed and continues even when the breaks are on, could that be an indication that the bearings are going, I have heard about this indication before but thought it would be much louder.
If it was to be my bearings, (I have hubs with sealed bearings, I think, 2000 sport) how would i check them?
Old May 14, 2004 | 05:51 PM
daerhldgs2's Avatar
daerhldgs2
Loose wheel bearings will emit a rumble but usually if you jack the vehicle up and grasp the wheel/tire in the 6o'clock and 12 o'clock positions you can get free play by working one hand against the other (push-pull) If no free play probably not the bearings then I'd look to the cardan joint at the rear of your trans/transfer case if 4X4. If the center ball is worn it makes a rumble and if the u joints are worn they squeal.
tom338
2015 - 2020 F150
65
Dec 4, 2015 04:23 PM
Ofourcobra
Feb 17, 2015 08:21 AM
gogreenwave
Jul 30, 2014 05:54 AM
JHoffman93
Nov 11, 2013 07:14 PM
mlisi585
1997 - 2003 F150
Apr 29, 2005 04:49 PM
