'00 7.3L Powerstroke Performance Upgrades?
Old May 13, 2004 | 11:25 AM
Induction Concepts's Avatar
Induction Concepts
Question '00 7.3L Powerstroke Performance Upgrades?
I own a shop that designs and fabricates twin turbo systems for gas engines and I really don't know squat about diesels. But I always have guys with diesel trucks coming in and wanting some performance increase and I'd like to be able to help them out.
My first thought was to install an electronic boost controller to allow him to turn the boost up. I'm also aware of the SuperChips MicroTuner and Evolution Programmer.
What do you guys recommend for the best bang for the buck? Most hp/tq for $500 or less?
I don't know what tranny he's got. He wants more power when towing a rather large trailer.
Thanks in advance for any and all info.
Rad Craig,
Old May 13, 2004 | 11:57 AM
johnsdiesel's Avatar
johnsdiesel
I would recommend getting gauges first, and then a 4" exhaust system and air intake (not a K&N). No way would I run a chip or programmer without these mods. A lot of guys really like the Predator as well as the SuperChips.
Are you a sponsor of this site? If not, just a bit of advice. Your posts will be censored if you link your business in your posts because it competes with MotorHaven, the main sponsor of this site. Maybe you could become a sponsor?
Old May 13, 2004 | 11:58 AM
Induction Concepts
No, I'm not a sponsor. I didn't think it would be a problem since we aren't a competitor.
Old May 13, 2004 | 05:57 PM
FTE Ken's Avatar
FTE Ken
Company names and links to your company are not allowed, competitor or not. Only site sponsors may use the forums in that manner.
Old May 17, 2004 | 09:35 PM
gymrat's Avatar
gymrat
Johnsdiesel, why are you against the K&N FIPK system on the 7.3? I thought the issue was with the makeup of the filter itself, on the drop in style only (particals in the turbo)? Or is it the reuasable vs. the replacable filter, perhaps you prefer the reusable better?
Old May 17, 2004 | 09:41 PM
johnsdiesel
The majority of PSD owners will tell you that yes, there is an issue with drop-in filters in a stock airbox, but K&N filters themselves do not filter that well. A simple physics 101 lesson explains a lot. In order to flow more air through the same surface area you must decrease restriction. By decreasing restriction you allow more particles to pass the filter. In other words, the only way to decrease restriction and maintain filtration is to use a larger, non-porouse filter like the AIS or Tymar.
Old May 17, 2004 | 10:51 PM
gymrat's Avatar
gymrat
Sorry John I subsequently caught your thread on around page 16 regarding this issue. Is there another filter such as Tymar which could fit the intake tube on the K&N FIPK system, or are you stuck with buying the hole enchilada? Spending more dough gives me heartburn.
Old May 17, 2004 | 11:08 PM
johnsdiesel
The part numbers for the filter are:
Donaldson part number B058011
Baldwin part number PA2818
The filter is designed to attach to 4" tubing. It may be too big too use with your intake. If it is, use it with the intake tube only. HERE is a picture of the filter.
Old May 18, 2004 | 12:08 AM
farmb0y's Avatar
farmb0y
Johnsdiesel-
I understand your point that to get more airflow you need less restriction resulting in less filtering. But from pictures I've seen of Tymar setups, the K&N FIPK system filter (conical filter) is almost the same size as the Tymar dry element filter. I can fully understand that point with the drop-in filters, since it is still the same size as the old filter, but "improved airflow", but I guess I don't see that it stands true for the FIPK set-up. I still think wet element filters are better IMO, and maybe I'm trying to rationalize since I have the K&N set-up. Any help on this??
Old May 18, 2004 | 12:11 AM
johnsdiesel
Well, they make the filters out of the same material. Drop-in or intake, it's the same stuff.
Old May 18, 2004 | 12:13 AM
farmb0y's Avatar
farmb0y
Good point. Thanks.
Truxx1956
Apr 13, 2008 08:47 AM
HiPoCP
19
Nov 8, 2005 06:22 PM
northernlights
Oct 8, 2005 10:28 AM
BlueOvalBaker
Nova Scotia
Feb 14, 2005 05:01 PM
Craig
Feb 3, 2001 12:43 AM
