Sponsored by: Auxito
oxygen sensor 1998 F150
Old May 10, 2004 | 08:27 PM
russ1109's Avatar
russ1109
Question oxygen sensor 1998 F150
How do I clean the oxygen sensor? How do I know if I need to replace it?
Old May 10, 2004 | 10:25 PM
F2504x4's Avatar
F2504x4
Hi and welcome to FTE,
your trucks computer will generally show a check engine light when a sensor fails, use the seach feature to look up info on o2 sensor's.if a check light does come on, go to autozone and they give you the codes for free, write them down and post them down and ask here or use the search.
Old May 10, 2004 | 10:28 PM
03f150man's Avatar
03f150man
if your engine is not throwing any o2 related codes,dont touch the 02 sensors. Just keep driving. Generally, drive sensors until they fail. But obvious exceptions such as the maf which needs regular cleaning.
Old May 10, 2004 | 11:54 PM
russ1109's Avatar
russ1109
thanks for the info. I drive in the desert...lots of fine dust. The engine started knocking about 5 months ago. It only happened when I accelerated. The engine light came on. I took it to a mechanic and he said it was the O2 sensor. He cleaned it and it ran fine. Last week it started knocking again. I thought it may be the start of an O2 problem..again.
Warbuggy
Modular V10 (6.8l)
Sep 9, 2014 01:26 PM
eclancy
Apr 3, 2012 08:18 AM
Ultramagdan
1997 - 2003 F150
23
Jan 18, 2009 07:23 PM
WENDOV
1997 - 2003 F150
Jan 11, 2008 10:21 PM
jrreagan
1997 - 2003 F150
Jan 29, 2005 08:07 AM
