Sponsored by: Auxito
Oxygen Sensor
Old Jul 8, 2002 | 10:21 PM
Ultramagdan's Avatar
Ultramagdan
Oxygen Sensor
Old Jul 14, 2002 | 12:32 AM
Mad Jack's Avatar
Mad Jack
Oxygen Sensor
[updated:LAST EDITED ON 14-Jul-02 AT 01:33 AM (EST)]I will be needing a O2 sensor for my '98 F150....................I know it goes on the catillac converter I have the codes for the sensor but where on the converter does it go on??? I can't seem to find the old sensor to replace it.
Old Jul 14, 2002 | 08:51 AM
nitro94's Avatar
nitro94
Oxygen Sensor
You have at least 3 maybe 4 02 sensors on that truck, which one needs replacing? 2 are close to the engine manifolds, one on each side. The other one or two are after the converter or converters.
Old Jul 14, 2002 | 07:13 PM
Ultramagdan
Oxygen Sensor
My truck has 4. 3 are fairly easy to get to but the one on the passenger side just south of the exhaust manifold is tough to get to. Before you replace any of them - pull the O2 sensors and wash them in gas and see if that eliminates your code. It worked for me.
Old Jul 15, 2002 | 07:02 PM
bosshoss's Avatar
bosshoss
Oxygen Sensor
Hey Mad. Let us know the code you have, and we might be able to tell you what sensor to change. Bank 1 is the drivers side. Bank 2 is the passangers side. sensor 1 is near the manifold, sensor two is near the converter, both sides. Good luck
Dave Powell
Old Jul 15, 2002 | 09:31 PM
nitro94's Avatar
nitro94
Oxygen Sensor
Guys remember this simple rule for O2 sensor banks. Bank one is ALWAYS on the same side as number one cylinder. This holds true for all makes and models. That puts Ford on the right bank or passenger side for rearwheel drive engines.
Old Jul 18, 2002 | 06:59 AM
Mad Jack's Avatar
Mad Jack
Oxygen Sensor
>Good luck
>Dave Powell
Hey Dave,
The Code on the sensor is 8-44F
Thanks
Mad Jack
aka Andy Blackwood
Old Jul 20, 2002 | 10:43 AM
z 97ford1's Avatar
z 97ford1
Oxygen Sensor
Pull out all of the o2 sensors and clean them with "electrical motor cleaner". Buy it at a auto store. This will remove the EXHAUST powder from the sensor.
Old Jul 22, 2002 | 09:05 AM
Mad Jack's Avatar
Mad Jack
Oxygen Sensor
Great, thanks alot
Old Jul 22, 2002 | 10:59 PM
rashirley's Avatar
rashirley
Oxygen Sensor
I have a 98 F250, (with a F150 body style) 5.4 V8 4X4.
All of a sudden the milage quit recording. The speedometer shows how fast I am going. All other guages work as does all else.
The only thing I've done recently is add a K & N fuel injection air cleaner system.
Any ideas on what happened. Or how to fis it?
Feel fee to email me at rashirley(No Email Addresses In Posts!)
Thanks
Old Jul 23, 2002 | 09:07 AM
wildfordgal's Avatar
wildfordgal
Oxygen Sensor
Hi Mad...? do you have any success? by the way I like your nickname
Old Jul 23, 2002 | 03:48 PM
simmerz99's Avatar
simmerz99
Oxygen Sensor
i'm having probelms with my 02 sensors as well
you say to clean them with gas, or electrical cleaner??
it's on a 99 F-150 with 5.4L Triton
Old Jul 23, 2002 | 04:54 PM
Fourtrax4x4's Avatar
Fourtrax4x4
Oxygen Sensor
Does anyone know if you can remove the catalytic converters on an F-150 without problems? Someone told me that you can't because the oxygen sensors. He said it wouldn't run without them, but another guy said there's a way you can do it. If anyone can help me I would really appreciate it.
2002 Ford F-150 S/C XLT 4x4 Dark Shadow Gray w/ Silver accent, Dual Flowmaster 40 Series, K&N Filter, Rhino Liner, Ventvisors and Bugshield
Old Jul 24, 2002 | 10:50 PM
Ultramagdan
Oxygen Sensor
I cleaned mine in gas. The goal is to remove the carbon build up. So electrical cleaner, carb cleaner, etc may work just fine.
As far as removing the cat converter - why? If your trying for max horses this could be a expensive way of doing it.
Old Jul 25, 2002 | 11:03 AM
Fourtrax4x4
Oxygen Sensor
I want to remove the cats so it will be louder and have a little more horsepower. There are no emissions test or inspections here so I don't have to worry about that.
