Sponsored by: Real Truck
Outta Ideas-Please help
Old May 7, 2004 | 12:54 PM
huntin' truck's Avatar
huntin' truck
Hi all, I'm turning to you again for an ongoing problem. I have an '01 F250 PSD, problem is pull during braking. Sounds easy but here's whats been done, new rotors, pads( 3 sets now), hoses,calipers,Turned rear rotors, new rear pads,ball joints, alingment, tires. Dealership still has the truck and they've disabled ABS & rear brakes and it still pulls. It will pull to the right at times then left at times or no pull at times. If you have any ideas please let me know, i'm outta them!
Thanks for any info.
Scott
Old May 7, 2004 | 01:04 PM
LOOnatic's Avatar
LOOnatic
Could also be brake pad pins not properly lubed so they would bind up, improperly torqued lug nuts(yes really).
Has it always done this since new or just lately?
Old May 7, 2004 | 01:09 PM
michaelmueller's Avatar
michaelmueller
I know you had an alignment, but did you check your ball joints?
wlihntr's Avatar
wlihntr
my 2001 has done the same thing since new, and i have done many of things you have tried. the best results are from something i just did. i had all my rotors(stock) turned and but on new "performance friction carbon metalic Z-rated" pads on all four. it is much better than it ever has been but still does it a little, sometimes
www.nationalfleetparts.com ...hope this helps
Old May 7, 2004 | 01:18 PM
huntin' truck
Had those replaced about 2 months ago and alignment re-checked last week, thanks for the idea though
Old May 7, 2004 | 01:19 PM
huntin' truck
It started after the first set of brake pads, 8 months ago, like I said on going problem.
Old May 7, 2004 | 01:44 PM
ForDen's Avatar
ForDen
Probably already thought about this, but I know mine did this before I put on the stabilizer. But it used to track ruts or grooves worn in old pavement and pull accordingly right or left. Just a thought.
Old May 7, 2004 | 01:57 PM
FortyFords's Avatar
FortyFords
Huntin truck ,did you post about this before ?
Someone did ,and I found for them that there is a TSB about this from Ford it concerns their stock of brake pads not being of the same friction compound.Which will cause your problem.
Have the shop chk this TSB # 03-19-10 brake pull right or leftI pay to read tsb's so I can't post it complete here without getting in trouble
ask the dealer to print it for you
Rich
Old May 7, 2004 | 02:29 PM
huntin' truck
I did awhile ago but I don't think you gave it to me then, but, I'll take it now!!
Thanks!
Scott
CobraGT40
Mar 19, 2014 11:36 PM
bulletpruf
Sep 2, 2012 03:31 PM
CobraGT40
Jul 14, 2009 05:47 PM
Eastpark
1997 - 2003 F150
Jun 6, 2005 12:01 PM
paulg
Jan 1, 2001 01:45 PM
