overheating.
Old May 7, 2004 | 12:06 AM
puf700's Avatar
puf700
overheating.
when i sit at idle for a long period of time say in the high school parking lot waiting for the busses to get out of the way or at a train crossing. my temp will climb and climb when i start moving again or shut 'er down then it will fall. do i just need to get a bigger fan OR try water wetter or somthing? any ideas.
Old May 7, 2004 | 12:11 AM
fordman428's Avatar
fordman428
does it have a fan shroud on it, if not id be finding one, because that will surely cause it to overheat, if it does have a shroud, an electric fan may do the trick, or one of them flex-a-lite fans with a think 6 or 7 blades may help, hopefully its not something internally wrong, good luck
Old May 7, 2004 | 12:23 AM
puf700's Avatar
puf700
this enigine was assembled from parts from a 360 and 390 its not really stock but im not sure whats up inside runs awsome pulls unbeilvble for a gasser. it dosen't have a fan shroud though, did they have those stock?
Old May 7, 2004 | 07:23 AM
fordman428's Avatar
fordman428
yes most of them had them stock, and they do help a lot, someone to the one off my 75 with a 390 and it was always overheating when it wasnt moveing, so i went to the junkyard and found one and hadnt had trouble sense.
Old May 7, 2004 | 05:08 PM
Ratsmoker's Avatar
Ratsmoker
You have the same problem I had. Your engine sets too far away from the radiator to not have a shroud. I went with an electric that had its own shroud and now it has no problems at idle.
jstoddard
Sep 15, 2016 09:03 PM
Atc210
Aug 2, 2016 06:28 AM
351Cleveland C4
1978 - 1996 Big Bronco
15
Mar 22, 2016 12:34 AM
coolfeet
Mar 21, 2016 08:17 AM
Ezalycasaid
Sep 19, 2015 10:22 PM
