1978 - 1996 Big Bronco
Rear Quarter Panel Replacement
Old May 6, 2004 | 03:54 AM
SproutW's Avatar
SproutW
Need options and possible costs for rear quarter panel replacement. My poor Broncos need some major rust holes repaired. Does both inner and outer panel need replaced and are the after market panels just as good as factory. Thanks
Old May 6, 2004 | 06:08 AM
RTM's Avatar
RTM
If the inner panel is good then it doesn't need replaced? As for the outer panel my buddy just did his fathers bronco and they glued the new panels. It didn't appear to be a bad job at all. The new glue isn't cheap but if you don't have a welder then you can't go wrong. If I was to replace them Iwould glue them as well and I have a welder. I think he used aftermarket panels?
David56
Apr 16, 2013 06:56 PM
mikeg216
Nov 22, 2011 07:56 AM
TheThickster
Jan 22, 2010 10:31 AM
Broncobudy
Oct 5, 2006 06:33 AM
rticwrrior2000
Dec 20, 2002 03:00 PM
