think he meant disc breaks on all 4 tires...there's a kit offered by ford motorsport, but i heard the actual disk doesn't fit...you should get the $5.oo catalog from them at your local ford dealer.
For $995 you get brackets, cables, rear discs, rear calipers, new proportioning valve, new Four Wheel disc brake booster (both front and rear fluid chambers are the same size - very important since Disc brakes have bigger calibers than rear drums)
That is the Kit I will be getting for my Bronco once I start to do more towing.
