2002 Ford F-250 diesel, shakes and knocks
Old Apr 28, 2002 | 11:11 AM
stacymm's Avatar
stacymm
Post 2002 Ford F-250 diesel, shakes and knocks
I was just wondering what is causing my truck to shake real bad, and it knocks. ALso when you start it up, it stalls then it cranks up. This started happening after my friend pushed the pedal and the truck was at 5000 rpms. It was in park when she did this. Please reply if you know what would be wrong with it. Thanks!!
Old Apr 28, 2002 | 01:42 PM
powerstroker250's Avatar
powerstroker250
5000 rpm? The pcm should be limiting the rpm. The redline is 3300 rpm. If it IS shaking and knocking, I would suspect internal damage if you did in fact exceed the redline.
Les
Old Apr 28, 2002 | 05:26 PM
FTE Ken's Avatar
FTE Ken
Old Apr 28, 2002 | 06:37 PM
The Diesel Dude's Avatar
The Diesel Dude
What kind of friends have you got?
If the engine did indeed go to 5000 RPM then you've got 2 problems. The first one, as stated in the previous post is the rev-limiter in the ECM is not working properly and the other is probably a bent push rod and/or a broken rocker arm fulcrum causing one or more (depending how many bent push rods you have) cylinders not firing. If your truck is box-stock from the factory, Ford should repair it at their expense because they programed the ECM and if the "high idle" doesn't cut the electronic governor in at about 3650 RPM, then they didn't program it right.
Old Jul 2, 2007 | 08:11 PM
dryfly's Avatar
dryfly
nice friends
Old Jul 5, 2007 | 10:47 PM
dnvoss's Avatar
dnvoss
you shouldn't be ever runnning a diesel at 5000 rpm
Old Jul 11, 2007 | 03:33 PM
7.3L DID TD's Avatar
7.3L DID TD
sorry have to send this one to the top, can't wait to hear the rest of this story!
Old Jul 11, 2007 | 03:37 PM
7.3L DID TD
Does our DP-Tuner F-5 raise the RPM limiter? Anyone know?
Old Jul 11, 2007 | 03:39 PM
HKusp's Avatar
HKusp
I doubt you'll get your answer. The original post date was in april of 2002 and it was the stacymm's only post.
Old Jul 11, 2007 | 03:44 PM
7.3L DID TD
no no that's this guys join date!
Old Jul 11, 2007 | 03:45 PM
7.3L DID TD
<TABLE><TBODY><TR><TD vAlign=top width="100%">Does our DP-Tuner F-5 raise the RPM limiter? Anyone know?
</TD><!-- KEN: 1-13-2007: show 300x250 ad-block to non-Club FTE users in the 1st post of every page --><!-- / Ken, end of hack --></TR></TBODY></TABLE>Ok have to quote myself here!
Old Jul 11, 2007 | 03:48 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
LOL guys this is from 2002, that was a good one,
Old Jul 11, 2007 | 03:51 PM
7.3L DID TD
Ok I see what you mean now! Poor guy probably jumped off a tall building somewhere.
Old Jul 11, 2007 | 04:59 PM
PETE'S_6.0PSD
yeep, getting 5000 rpm out of 7.3, he was for sure some guru mechanic,
ok just j/k, i guess we never know,unsolved mistery of the 7.3 forum,
dmanshane
16
Mar 20, 2012 12:27 AM
79sparky
16
Jan 15, 2012 08:52 PM
gvfd107
21
Dec 19, 2011 07:16 AM
rfrasure
Oct 19, 2010 09:00 PM
bootsman
Mar 11, 2006 12:46 PM
