I have a 1975 ford f250 when you take it up to 35or40miles an hour it starts shaking really bad . When you go up to 60 it quits shaking can someone tell me what the problem is .
do you have a 2 piece driveshaft? if so its possible someone removed it to do u joints and installed it without lining up the u joints. the drive shaft is 0 balanced when they are lined up.
I'd bet it's your tires. Mine have 75% tread on them, but they've been plugged so many times that they won't balance. I start to shake a bit at 40, then it lightens off until about 65 and it gets pretty bad. I just can't justify spending $400 worth of tires on my $500 truck yet.
I've expierenced this before also. Tire held air but when I took the tire off and rolled it.....it was very noticeable that the belt had broke. Also, The speed and shakyness was the same speed you are expierenceing. If I go 60-70 No noticable shaking
Try jacking up each tire and spinning it to see if it spins true. I had a bad vibration one time and did this and found out I had a bent rim(hit a log doing donuts in the pit).
I wil add my experience here.
If you get a shimmy at certain speed range, then it goes away at higher speeds, then the culprit in most cases IS a tire with a broken belt.
Change the front tires to the rear and visa versa and see if this changes anything. If so, you have a bad tire.
BTW, a tire with a broken belt should be easy to find when you try to balance it. The tire shop guy will let you know if you have one after he is unsuccessfull in balancing it.
