Cigarette Lighter Wiring
Old May 5, 2004 | 03:55 PM
pizalm's Avatar
pizalm
I have 76 F-100. I got it and there is no wires going to the cigarette lighter. Can someone tell me where the wires come from. There's a green wire coming from a bundle going across throug the dash just hanging there, is this it because is doen't go to anything and everythign else works
Old May 5, 2004 | 05:09 PM
prcrboy's Avatar
prcrboy
I'm not sure about 76, but 77-79 the lighter wire was green and had a stripe on it. I can't remeber what color. It came from the fuse box. If you have a volt meter check it. It should have 12v on it at all times. They were doubled fused. A 20 amp fuse for aux. equipment, cruise, etc. then a 15 amp fuse for lighter and other interior lighting loads. Check owners man.
Old May 5, 2004 | 05:19 PM
Mil1ion's Avatar
Mil1ion
It should be a wire coming out of the main wiring harness right near the lighter.
It has a 90* plug on the end of it.
Old May 5, 2004 | 10:06 PM
Franklin2's Avatar
Franklin2
I think my lighter wire in my 1980 is green with a yellow stripe. It will be a little heavier than the rest of the wiring under there.
Old May 6, 2004 | 11:28 PM
pizalm's Avatar
pizalm
I'd check the owners manual if i had one, and if find the wire, how do I wire it?
Old May 7, 2004 | 12:54 AM
Franklin2's Avatar
Franklin2
I have never looked at one very close, but the center pin is the hot wire, and the outside circumference is ground. It may ground automatically to the dash if it's metal, or it may have a seperate short piece of wire that bolts to a good ground.
Old May 7, 2004 | 01:06 AM
Mil1ion's Avatar
Mil1ion
Here is a view of the 78 underdash wiring.
Look right in the middle of this illustrations and you will see a 90*angle connector,that is for the lighter.
6th set of text down from the top where it says {retainer assembly}.
http://www.clubfte.com/users/mil1ion...ingharness.JPG
Old May 7, 2004 | 07:01 PM
pizalm's Avatar
pizalm
i'll check the volatge and if it's 12 i'll wire it in because the dash is metal. If it doesn't work I'll just leave it as is for right now because i don't really need it. Thanx for the help.
whiteboyslo
Nov 8, 2014 05:03 PM
xaviar
Feb 3, 2014 10:18 PM
1979 300i6
Jul 20, 2013 09:04 PM
Webslinger
May 23, 2011 03:44 PM
rebelbob
Offroad & 4x4
Jan 5, 2003 05:58 PM
