rough idle
Old May 22, 2002 | 01:34 PM
mwillingham's Avatar
mwillingham
rough idle
I apologize if this has been addressed before, but I can't seem to find an answer that fits my situation exactly.
I have a 97 PSD. Once it warms up, it has a problem at idle. It usually occurs right when the clutch is depressed. The engine shakes so bad, i feel like it's going to throw me from the truck. It lasts for about 5 seconds and then equals out. If I give it gas, it stops. Any ideas? Also, it has 87,000 miles on it and is under warranty until September. Would this problem be covered under warranty?
Thanks
Old May 22, 2002 | 03:03 PM
powerstroker250's Avatar
powerstroker250
rough idle
How is the oil level? How old is the oil? Could also be an injector going out. You should have it scanned for codes first.Is there any rattling noise? If so, have the dealer or a competent tranny shop check the dual mass flywheel. If you idle it with your foot off the clutch and it rattles it's the DMFW. I just had the LUK single mass clutch upgrade done to my company truck(97 PSD) which had the same symptoms you describe.
Les
Old May 22, 2002 | 07:11 PM
The Diesel Dude's Avatar
The Diesel Dude
rough idle
Probably your dual mass flywheel about to crap out on you. If you still have warranty left, I'd get it in to Ford for review.
Old May 27, 2002 | 08:27 PM
jelrod_tn's Avatar
jelrod_tn
rough idle
My 95 PSD has the same problem. How much does a Duel Mass Flywheel cost? Can I install it myself?
Old May 28, 2002 | 11:41 AM
powerstroker250
rough idle
I don't think you want to put another DMFW back in it, you'll just end up with the same problem later plus they are around $900 from what I've heard. Instead put in a LUK upgraded clutch with single mass flywheel in it. They hold more power and have a lighter pedal effort. Try the online store on this site or www.carolinaclutch.com www.southbendclutch.com
Les
Old May 28, 2002 | 06:06 PM
ddestruel's Avatar
ddestruel
rough idle
azchris
6.7L Power Stroke Diesel
15
Aug 26, 2013 10:43 AM
srkr
Oct 29, 2010 05:59 PM
cyclone cj
Modular V10 (6.8l)
Jul 30, 2004 02:57 PM
2shabby
Mar 25, 2004 01:29 PM
Rollie
Aug 27, 2003 07:38 PM
