diesel coversion
Dusty
Why Buy new when you can build and tailor it cheaper?
F-350 4x4 ext cab Short Bed Green Monster, it is now Sporting a 300HP 715lb/ft Dyno rated 5.9L 12v Cummins diesel w/ NV4500 5spd and custom NP205 ford T-case w/ rear spicer 1410 yoke, Converted to Sterling 10.5 gears w/3.73 gears using the 41 spline pinion and 1410 U-Joints, Power-Lok equipt Dana 60 front, 33's on 16x8" Outlaw II's. (Used to have)205000 miles, Mass air 460 w/ performance heads and a E40d to 5spd conversion and Doug Thorleys. Old EFI 460 @10 MPG to the 12 V @ 23.2 MPG @ 75 MPH and loving it.
My other toy is a '69 CJ-5 354 Hemi 4 spd 4.88's 32x12.50 MThompsons w/ power-lok 44 rear.
Good Luck
It is one of the most widely used engines from skidders, to class A motor homes, freightliners and boats.
Kenworth is right stay away from the wiring involved with the PSD it would really be a headache plus your firewall would require remodeling since the PSD down pipe would require more room behind the engine.
My old 95 PSD cost me a fortune in injectors a little over 100K miles, i think the final bill was upwards of $2700 including the replacing of the cam position sensor which failed. a set of cummins 12 Valve injectors cost $369 from cummins northwest and $60 labor/ 1 hr to install and are mechanical. So you need to run the numbers and consider all variables a 7.3 IDI would be an interesting choice but that also has its ups and downs it would definately benefit from a turbo and a screwdriver to the pump's timing. Another thing to consider an I-6 12 valve uses an inline high pressure pump which has twice and three times the life span of a Rotary pump (used on earlier cummins and also on V-8 IDI diesels) Also when you do this keep in mind tire size, gear ratio and RPM performance range. My cummins comes online from idle but hits hard from 1500-2200 and all the way to 2400 then it dies, my PSD was a little sluggish in the lower RPMs but really showed promise in my driving RPMs from about 1800 or 2000-3200 and never died off really but it also had 4.10's which worked well. the cummins works better with the 3.73's and 3.54's and 33" tires. Lower RPMs
Good Luck
Dusty
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=4039&.jpg
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=474&.jpg
Cost is a matter of preperation and shopping, i sold my 460 parts and cut the conversion price tag by 2/3 most the time i wouldnt have been that lucky a complete motor tranny and t-0case can be bought for 3000 with 179000 mile on them to 4500 with 70000 miles, it is best to find a ford or dodge that has been wrecked buy it at an insurance auction for 4-6K then sell what parts you can on ebay and cut the cost. either way it is alot of work and you still have a truck that has x# of miles on it in body stress and frame fatigure including axles and springs.
