Multiple Error Codes
Old Mar 29, 2016 | 07:18 AM
awojtowicz's Avatar
awojtowicz
i had an error code of p2004 on my 05 expedition. we changed out the intake manifild runner control. that error went completely away but now i have 3 other errors showing up with check engine lit up. i have P0171 (bank 1 combustion too lean), P0113 (intake air temp sensor 1 circuit high input) and P0202 (Cylinder 2 injector circuit malfunction). We changed out cylinder 2 fuel injector. the engine was real rough like when a coil pack goes. so we changed out a new spark plug and coil pack. now everything seems to run fine but the check engine stays lit and the same error codes are still there. i also changed out air filter. what do you think the problem is? im scared to think the intake manifold has to come off again. that was an all day job.
Old Mar 29, 2016 | 08:02 AM
Skauber's Avatar
Skauber
P0202 usually means the injector isn't properly plugged in, check the connector and make sure it's making a good connection. P0171 is probably related to the injector that isn't working. P0113, if I'm not mistaken, the intake air temp sensor is integrated in the MAF sensor. Check the connector going to the MAF and make sure all the wires are making good contact.
Old Mar 30, 2016 | 07:00 AM
awojtowicz's Avatar
awojtowicz
well i drove home yesterday and after stopping in a store on way home the check engine light went off. i guess it took 200 miles to reset. thanks for help.
Chet j.
Modular V8 (4.6L, 5.4L)
Aug 28, 2017 01:27 PM
bigredtruck
1983 - 2012 Ranger & B-Series
16
Jun 29, 2016 09:24 AM
Uzzy
Escape & Escape Hybrid
Oct 18, 2014 11:24 AM
mr.noodi
Jul 13, 2013 08:53 PM
rguy
Mar 2, 2006 08:40 PM
