Timeing
Old May 2, 2004 | 09:59 PM
awking55's Avatar
awking55
Timeing
What kind of performance Benefits will I get by setting my timing gear straight up? 79 f100 400 c6
Old May 3, 2004 | 03:52 PM
bubbaf250's Avatar
bubbaf250
By setting the cam timing "straight up", you will get the performance that your camshaft was designed for by its manufacturer.
In essence, advancing the cam timing will lower the rpm range of the cam's effective power band, retarding the cam timing will raise the rpm range of the cam's effective power band.
Depending on the cam design, you might get more low-rpm torque (and less high-rpm horsepower) by advancing the cam from the manufacturer's specified timing, and you might get less low-rpm torque (and more high-rpm horsepower) by retarding the cam from the manufacturer's spec. This works only if the cam design allows for it, and only if you change the cam timing in very small increments, usually no more than 4 degrees either way from the spec timing.
Old May 3, 2004 | 09:05 PM
awking55's Avatar
awking55
Sounds like 0 degrees is the way to go.
tlb
May 9, 2011 08:55 AM
85300
18
Apr 14, 2010 02:26 PM
Placermike
Washington Chapter
Jun 4, 2009 09:09 PM
bscrusher
Feb 15, 2008 01:45 PM
sds2000
Jan 23, 2008 08:00 PM
