302 ignition timing
Old May 7, 2011 | 10:34 AM
tlb's Avatar
tlb
302 ignition timing
What should the timing for a 1970 302 with a 2 barrel carb be set to?
Thanks
Old May 7, 2011 | 01:54 PM
52 Merc's Avatar
52 Merc
Anywhere from 6 to 10 degrees BTDC initial would be fine. The more the merrier, until it detonates.
Old May 9, 2011 | 08:55 AM
Fordman49F1's Avatar
Fordman49F1
The more the merrier indeed...mine is closer to 12 degrees. Most books say anywhere from 6 to 8 degrees, I try to start at 8 degrees and push it to 10, if not more.
302Meister
Feb 10, 2015 01:40 PM
slave2dafords
Dec 10, 2002 11:14 AM
lvmoose007
Nov 5, 2002 07:04 AM
Franklin2
Jun 25, 2002 11:20 PM
Torky
Nov 20, 2001 04:17 PM
