Computer Chips & Tuners
Smokin
Old May 1, 2004 | 10:23 AM
Benny R's Avatar
Benny R
Unhappy Smokin
I just installed my superchips 1715 tuner on my 02 f-250 5.4. I also have the K&N fipk on it and i took off my muffler and have a y-pipe with duals. I'm running the performance program with 93 octane. When i start my truck it smokes out the pipes is this bad or did I do something wrong
Old May 1, 2004 | 11:09 AM
FTE Ken's Avatar
FTE Ken
The Microtuner is not designed to run with X/Y/H pipes, mass air flow sensor changes, long tuber headers, head changes, etc. The air/fuel ratio is screwed up because of your changes... it needs custom programming.
Old May 1, 2004 | 04:02 PM
Benny R's Avatar
Benny R
I did not know that. the place i bought it from told me that it will run better and make more power with the other mods. When I return it to stock it doesn"t smoke anymore, will it hurt my truck down the road if i run it like that.
Old May 1, 2004 | 05:38 PM
openclasspro's Avatar
openclasspro
ken- i think he took off muffler , y 'ed it there then dual pipes- all post o2 sensor location- am i correct?
Old May 2, 2004 | 12:54 AM
FTE Ken's Avatar
FTE Ken
I'm not sure I understand what you said. Did you say he left the O2 sensor location alone?
Old May 2, 2004 | 06:04 PM
Benny R's Avatar
Benny R
smokin
Thats right I took off my muffler and put on a y pipe thats 3 inch singleside after the cat then splits into 2.25 duals and I only have one o2 sensor thats on the manifold. The place that i bought it at installed it for me while he talked me through the install when I got home I read the instructions and see that you have to disable the fuel system if this was not done could it be the problem? Thank you for your replies.
Regulator1988
Apr 5, 2012 08:00 AM
clunker86
Exhaust Systems
Aug 20, 2007 01:53 PM
bjarnold1
Sep 24, 2006 01:09 AM
Burnt 1
Modular V10 (6.8l)
Dec 21, 2003 07:14 AM
stover007
May 1, 2002 11:42 PM
