CD player mounting kits.
Old May 1, 2004 | 08:59 AM
TheMachfather's Avatar
TheMachfather
Down at walmart I saw they had the harnesses and the plastic mount kits for 73+ fords, jeeps, etc. On the back though for F-series it said 1980+. So now would those still work in my '77? Or do I need to just rig up somethin myself? I'd think they'd be the same.
Old May 1, 2004 | 09:05 AM
jcduerr's Avatar
jcduerr
Talking
i had to rig up some thing from the plastic mounting kit it took some cutting on the kit but it holds it in there
Old May 1, 2004 | 03:43 PM
Monster 78 F-150 4X4's Avatar
I just bought a GM kit and hacked it up. I only used the ring out of it than I made brackets on it to mount it in the dash.
Old May 2, 2004 | 09:49 AM
jsooke's Avatar
jsooke
Just completed mounting on a '79. Used the same kit you are talking about.
However, alot of extra work. First had to remove the metal bracket that supports the factory radio and heater controls. I then cut off the bottom piece that holds the radio, leaving two tabs hanging down below the heater controls. On the tabs drill a hole as close to the bend as possible.
Then remounted this piece and the controls.
In the kit you are referring two there are a mulitude of parts.
Take part FRB-534 (Main Bracket) and break off all the parts except the tab on the bottom (refer Page 8 in instructions). The tabs are designed to break off. Then take the two J-1 (jeep Wrangler Brackets) and slot them into the slots at the top of the FRB-534. Break off the top of the brackets so as there is just one mountiing hole. Mount these brackets to the holes drilled into the heater bracket.
This part I have not done yet, but for more support you can drill holes in the dash where the bottom bracket that you left on the FRB-534 and screw to the dash.
Cut out the plastic dash. For my install there was only a little to cut out. A bit along the bottom and the sides of course.
Put it all back together with a back support (Usually comes with the radio).
I have been driving without any problems for the last week, however have not been out on the back roads to really test out.
Jay
Madathlon
93
Jun 22, 2021 09:05 AM
onug
Dec 31, 2011 11:23 PM
Home made SVT
Nov 15, 2009 09:35 PM
F250racer
Jul 9, 2009 12:55 AM
fishin machine
1978 - 1996 Big Bronco
Sep 19, 2006 12:00 PM
