door ajar
Old Apr 30, 2004 | 11:01 PM
Ford from above's Avatar
Ford from above
door ajar
I have a 2001 F350 psd 4x4. Is there a problem with the door sensors, because one other truck we test drove had this warning on? Also, where are the door sensors?
Old Apr 30, 2004 | 11:16 PM
farmb0y's Avatar
farmb0y
The door sensors are located on the actual door latch, there on the back of the door. You have to take off the door panel on the inside and get in the door to get to it. I've changed mine before because of that problem. It is fairly common that they go bad.
Do a search in this forum for that, and you'll find a lot of threads related to it.
A lot of people try squirting it with oil, but I think it's almost making it worse. Dust will stick to the sensors and everything else. It'll work for a while, but I'd suggest changing them soon, just to solve the problem.
Old May 2, 2004 | 08:32 AM
Jerrod's Avatar
Jerrod
When I had it happen my dealer just said take some WD-40 and spray it in the latch on the door then work it a few times......no problems since!
Old May 2, 2004 | 08:38 AM
subdewd's Avatar
subdewd
WD 40 work for me too, I had to do it twicw to get it to work
Old Aug 1, 2005 | 05:36 PM
David Howard's Avatar
David Howard
Unhappy Door Ajar Sensor
To FarmBoy,
I have a 2002 F350. I am not familar with take off the door panel. Can you provide a little detail on getting the door panel off?
Old Aug 1, 2005 | 05:44 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i have the same problem on my 2002. its a crew cab, so i dont know which door its coming from i have tried to spray Gibbs in the latch area, ill go back with WD-40 and try again. open and close the dooor 10-20 times and see if it works.
Old Aug 1, 2005 | 06:02 PM
JOE-M's Avatar
JOE-M
I had the same problem as you. Soaked down the latch on the driver's door (that's which one it was the last time) a few times before I figured out it was the back door.
Joe
Old Aug 1, 2005 | 06:17 PM
AKDieselMan's Avatar
AKDieselMan
I also ahd the problem and fixed it with WD40, been over a year now so I don't think the problem of dust and gunk is making it worse. A lot cheaper than removing the door panels and possibly breaking something.
Old Aug 1, 2005 | 06:40 PM
David Howard
Just tried wd40 procedure on all the doors. I have a crew cab. Open and closed about 20 times per door. Same problem.
Old Aug 1, 2005 | 08:02 PM
magnum300's Avatar
magnum300
How much did you spray I had to give mine Quite a soaking, spray it a few more times and see if that fixes it
Old Aug 1, 2005 | 08:25 PM
JOE-M's Avatar
JOE-M
I believe the key word here is "SOAKING". A regular spaying might not do the trick. Make sure you get it up in there real good.
Joe
Old Aug 1, 2005 | 09:31 PM
Ford from above
door ajar
I started this thread a year ago, and haven't had to squirt the doors since. Make sure you spray generously
Old Aug 2, 2005 | 11:13 AM
AKDieselMan
BAsically what you have to do is wash away all the grease and grime causing the switch to stick. So yes, good advice is to spray generously. Since WD40 doesn't leave a heavy grease behind it is a good choice for this problem. After you ahve sprayed generously you still could have a bad switch.
TampaDave
May 5, 2010 05:04 AM
calibob
1997 - 2003 F150
Dec 27, 2008 01:47 PM
fobranch
Feb 6, 2008 06:15 AM
bigbrad96
Mar 26, 2006 07:51 PM
WABIT
Electrical Systems/Wiring
Apr 11, 2004 10:54 PM
