Sponsored by: Auxito
door ajar
Old Nov 27, 2008 | 02:50 PM
calibob's Avatar
calibob
door ajar
I have a 1998 f150 4x4 and the sensor keeps saying the door is ajar. Of course the courtesy lights and the bed light stays on. How can I unhook the sensor or where is it to replace.My battery is good but only for so long!!
Old Nov 27, 2008 | 06:33 PM
steve(ill)'s Avatar
steve(ill)
its probably in the door latch. look at the wires that go into the door between the hinges. if you dont see any switch there, they are in the door latch. take the door pael off.
Old Nov 28, 2008 | 11:25 AM
Ron W.'s Avatar
Ron W.
Use brake cleaner or carb cleaner on the latch, spray it into the hole in the door and then spray some WD40 or an equivilent lubricant in the hole to lube up the latch. Then (sounds funny) but slam the door several times, that should take care of the problem. Drivers side is most often the culprit.
Old Nov 28, 2008 | 11:38 PM
afc2001's Avatar
afc2001
I had a 99 f150 extended cab with the four doors and I had the same issue and if memory serves me correct the sensor/relay (or whatever it is) is in the door and I believe is part of the light in the door. As long as the door is closing properly I would check with your local dealer and just buy the sensor or relay or what ever the part is.
Old Nov 29, 2008 | 12:43 PM
jimm66's Avatar
jimm66
I had the same problem. WD-40 fixes it.
Old Nov 30, 2008 | 12:22 AM
papajoemrt's Avatar
papajoemrt
I had the same problem but only in the summer with dirt and dust. Thinking it was an electrical thing in the latch, i sprayed contact cleaner and it got rid of the grime in their. That also works if it comes back try that way as well.
Old Nov 30, 2008 | 04:20 PM
BigGrizz76's Avatar
BigGrizz76
I second the wd 40-- common problem w/ fords from this era...easy fix
Old Nov 30, 2008 | 04:55 PM
jimm66's Avatar
jimm66
The good thing about WD-40, it doesn't hurt anything like the plastic parts.
Old Dec 27, 2008 | 11:26 AM
Robert E's Avatar
Robert E
Robert E
I tried the wd 40 trick and it worked great !
Thanks for the suggestions to everone .
Old Dec 27, 2008 | 01:47 PM
jimm66's Avatar
jimm66
Welcome! Glad it worked. Lots of useful info here.
GTBksRule
Electrical Systems/Wiring
Apr 22, 2013 01:47 PM
Jamie Arceneaux
Mar 16, 2013 09:05 AM
TampaDave
May 5, 2010 05:04 AM
hush210
1997 - 2003 F150
Mar 19, 2008 06:24 PM
fobranch
Feb 6, 2008 06:15 AM
