E4OD - PSD 1995 F250 4x4- BIG PROBLEMS??
Old Sep 28, 1999 | 02:27 PM
Dan's Avatar
Dan
In August I posted a problem with my transmission. The OD light began flashing and it started shifting really hard. I have since had it rebuilt twice by the dealership. I have no confidence in this transmission now and will be unloading the truck in the spring after fishing season. I use the truck to haul a 1000# camper to Cape Hatteras and surf fish. The rebuilds cost a lot of money because I made the mistake of trusting a ford dealership. I now disengage the OD when driving around town with the camper on. I don't know of any other changes to make to driving habits. I have heard that you should change the transmission fluid more often these days perhaps at 10K. Here is a list of the most costly parts from the rebuild.
F7TZ-7902-CARM CONVERT 956959
F81Z-7A103-BA PUMP AS 061304
F5TZ-7B446-A GEAR AS 873459
F7TZ-7A398-BA PLANET 969956
F9TZ-7D063-A GEAR AS 781649
F81Z-7D064-AA SHELL – 032368
F2TZ-7D006-A PLANET 828990
F0TZ-7C391-A KIT 344410
Good luck to anyone else with this transmission and I hope this helps someone.
Old Jul 5, 2002 | 04:11 AM
newlystroked's Avatar
newlystroked
:-X12 Dan, I had similar symptoms with my truck, after I rebuilt the freshly rebuilt transmission, symptoms prevailed. Did some research and changed the Manual Lever Position Sensor and Speed Sensor on the speedometer cable at a cost of $84 it cured the problem. Good Luck!!!Let me know how you fare!!!
Old Jul 5, 2002 | 08:16 AM
spartamouse1's Avatar
spartamouse1
just courious why they rebuilt it instead of putting in a ford reman exchange? the exchange is less expensive, better warrenty, more dependable. how much was your bill when it was all done? exchange and labor is usually under $2500.
Old Jul 5, 2002 | 11:40 AM
The Diesel Dude's Avatar
The Diesel Dude
ludis
Apr 11, 2024 08:21 PM
ng19delta
18
Nov 24, 2016 10:19 AM
hdman6
Jun 14, 2016 08:58 AM
