Cruise Control Problem
Old Apr 29, 2004 | 08:37 PM
PickSty's Avatar
PickSty
I have a '95 Ford F-150 and all I have to do to disengage the cruise control is to tap lightly on the brake pedal. On my '96 F-250 PSD, I have to give it so much pressure that I start slowing down and then the engine speeds up, before it will disengage. Is there some kind of sensitivity adjustment on this thing? Thank you.
Old Apr 29, 2004 | 11:19 PM
BigBully's Avatar
BigBully
Are you 100% sure your Brake lights are working on the 96?
Old Apr 30, 2004 | 08:00 AM
mueckster's Avatar
mueckster
Check the pressure switch on the brake master cylinder to see if it breaks the circuit when the brake is applied.
Old May 1, 2004 | 05:08 PM
PickSty's Avatar
PickSty
Thanks for the help, fellas. It was the brake light switch under the dash on the brake pedal. Fixed the cruise control as well as making it much easier to shift out of Park.
TruckingBill
Aug 20, 2014 01:47 PM
cornking
Sep 13, 2011 10:08 PM
Buford
May 12, 2010 07:12 PM
STEVESMITHOCNJ
Oct 12, 2007 10:49 AM
fgibby
Oct 10, 2007 12:08 AM
