Cruise Control Problems
Old Sep 6, 2011 | 09:42 PM
cornking's Avatar
cornking
My cruise control doesn't disengage when I tap the brakes. I have to really slow down for it to disengage. If I hit the clutch pedal the engine races as I slow down or re-engage the clutch. It does disengage with the switch on the steering wheel.
Where should I start to look for the problem?
Old Sep 6, 2011 | 09:53 PM
Aune163rd's Avatar
Aune163rd
There is a pressure switch on the brake itself, its small and just behind the pedal arm or near it(dont remember rightly). It might be dying or loose. It sounds loose....
Old Sep 7, 2011 | 07:12 PM
cornking's Avatar
cornking
Is that the switch on the pedal with the wires coming out of it? How would I test it?
Old Sep 7, 2011 | 08:19 PM
Marianna2003's Avatar
Marianna2003
It's a dump valve. It is supposed to dump the vacuum going to the diaphragm of the CC unit. There should be one on the brake & clutch pedal.
Old Sep 9, 2011 | 10:01 AM
cornking's Avatar
cornking
got it fixed, thanks for the help
Old Sep 9, 2011 | 02:06 PM
Marianna2003
So, what did you do to fix it???
Old Sep 10, 2011 | 01:25 PM
cornking's Avatar
cornking
I am not a backyard mechanic. So I did what I always do, I went to my mechanico in the pueblo. I tried in my best Spanglish to explain the problem and show him where to look. There are very few diesel pickups and vans around here, so pointing Gustavo in the general direction helps. I am not sure what he did but I will go by next week and ask him.
Old Sep 10, 2011 | 02:46 PM
Aune163rd's Avatar
Aune163rd
Lol, gotta love that kind of mr. fixitstuff haha.
Old Sep 13, 2011 | 09:37 AM
cornking's Avatar
cornking
I went to the pueblo and saw my mechanico Gustavo. He told me it was some electrical connection that came apart or need cleaning on the switch on the brake pedal. I am not sure which as my Spanglish has limitations.
BTW, my cost of repair was 100 pesos ($8 US). You got to love that.
Old Sep 13, 2011 | 10:56 AM
eatont9999's Avatar
eatont9999
Mine does that, too. I have to more than tap the breaks for it to dump the vacuum. It's not ridiculously bad but I have slowed down a bit and then it takes off again.
Old Sep 13, 2011 | 10:08 PM
cornking's Avatar
cornking
That is exactly what my truck did. Check and clean the electrical connections on the brake pedal. That is what my mechanico did.
hotboxdp
1997 - 2003 F150
May 25, 2016 07:33 PM
escape04
Escape & Escape Hybrid
Jan 17, 2012 01:22 PM
hacking_in2002
Apr 27, 2011 08:05 PM
sammydiesel
Mar 17, 2009 12:47 PM
yampy4trux
1983 - 2012 Ranger & B-Series
Aug 29, 2001 09:34 PM
