Harsh cruise control
Old Oct 9, 2007 | 10:01 PM
fgibby's Avatar
fgibby
Whenever I disengage the crusie on my 07 f350 it feels like a quick and firm stomp on the brake. It is worse when towing or under load. Anyone else have this problem?
Old Oct 9, 2007 | 10:07 PM
04Xcursion's Avatar
04Xcursion
Are you running a tuner? This effect is quite common on a lot of the files because the converter stays locked when you cancel the cruise, you can get around it by accelerating a little and then cancelling the cruise when you've still got your foot in it. Then just let off on the accelerator.
Old Oct 9, 2007 | 10:13 PM
LaxPlaya21's Avatar
LaxPlaya21
My main concern with the cruise control is engaging it. When engaging I will lose around 5-8mph before it finally kicks in, then it accelerates back up to where I initially engaged it. Weird
Old Oct 10, 2007 | 12:08 AM
wb6anp's Avatar
wb6anp
I think that is normal, my '05 did this, my '06 does it as does my wifes freestar. It is just fords programing.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
